Results 1 to 6 of 6
Thread: toto toilet dimensions from pipe to front
    Default toto toilet dimensions from pipe to front
    I was interested in the Toto Drake, but it looks like I only have 18 inches from the pipe center (bolts) to the door path and not 18 and a half. Looks like most need 18 and a half, maybe a little more if the lid extends past the front of the toilet. Not all of the toilets have that dimension on them. I thought the round ones would be shorter, but they appear to be the same. I have a 12+ inch rough-in. I wanted a one piece elongated. The old one appears to be about 16 inches for that dimension.
    Any idea what that dimension is on the others?
    Can I change a 1.6 to a 1.28 just by changing the flapper?
    The Toto Drake and Ultramax can be ordered with either the 1.6 gallon parts or the 1.28 gallon parts.
    The elongated bowls, which are 28" long, normally have about 1" of space at the back with a 12" rough.
    That nomally makes it 29" from the wall to the end of the bowl on a 12" rough.
    Right, but in my case, it is a tight fit. In this diagram, it shows me the measurement that I need to know - bolts to the front 18.5, but I need 18.0 inches or less and other installation manuals for Toto do not give that dimension. See the attached diagram.
    It should be 17" from the center of the drain to the end of the bowl.
    Sep 2006
    MN, USA
    I've also got a narrow spot and unfortunately I went with the American standard compact EL(2007) since it's only 27.?? inches from wall to front. (it's good at flushing golf balls, but not long slender objects due to the sharp bend before the flange)
    Given the tight tolerances you might have to measure it at a store.
    If the hole to wall distance is known you might be able to do some math, however most manufactures add in tolerances to the drawings to compensate for manufacturing variations.
    Important note – I don’t know man made laws, just laws of physics
    Dec 2007
    Quote Originally Posted by Bill Arden View Post
    LOL
    The next golf ball I poop will be the first one....
