SLB
Two questions regarding the installation of a p-trap for a recently relocated bathtub. Can the p-trap be the type that uses compression nuts/washers or should it be the fixed (glued joints) type? Also, I was told that local code allows short (<5 feet) horizontal drain lines without a cleanout as long as they are not connected to a lavatory or sink. Is this acceptable? My bathtub drain needs about a 24" horizontal run from the point where I make the vent connection to the main drain line.
Regards,
Steve
Regards,
Steve
