Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Leaky and Ugly Faucets
    Default Leaky and Ugly Faucets
    Hello to All. I am a new memeber and hope to find answers to a lot of questions in the future. I will be remodeling my basement and plumbing will be involved. I have done some plumbing, but not to the extent of what I am going to be doing in the near future. Here is my first question.
    I just recently bought a house with some leaky shower faucets. My wife hates them. I have searched all over town for “O” rings, but nobody knows what type of faucets I have. Even if wanted to replace the complete faucet I would not be able to do that without knowing which manufacturer to choose from. I really do not want to tear up my wall to change out the fittings on the copper pipes. Does anybody recognize the manufacturer of this 1987 model faucets? The sink ones match the bath tub/shower faucets.
    Thanks in adavance
    Feb 2005
    Talking that is ugly
    I have not got a clue...
    change it out
    Default faucet
    That is a "third party" faucet, which could use a common base with their specialized trim, so you have to know who made the internals. It could be Central, Price Pfister, or someone else. Once you know that then you can find out if there are other parts still available to change it.
    Thank you for the information I am a step closer than where I was. Do you think if I photographed the shower diverter you could possibly identy the internal part manufacturer? If so I will post the photograph no later than tomorrow.
    Tim,
    It is ashame to replace those faucets, I like them. Can't you talk your wife into keeping them and just fix them?
    Cookie
    Default diverter
    The diverter is usually as distinctive as the stems, and easier to remove, so give us a picture and see what we can do with it.
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    The handles look like the American Standard, Amarilis
    Thanks for all the replies. Sorry Cookie, the gold fixtures just have to go. The previous owner had gold everwhere in this house. Her name was Rose and she also had rose wall paper everywhere.
    So..., I could not remove the diverter due to corrosion. I removed the cold water faucet internal parts and took two pictures. The diverter is the same set up. Thanks for any help in advance from both professional and home grown talented plumbers.
    Default faucet
    That stepped down stem does agree with the American Standard Amarillus drawing.
    Thanks to all who help and provided encouragement replies.
    A question for Know and HJ. Since American Standard Amarillus has been identified as the kind of faucets I have in my bathroom, do I have to stay with American Standard Amarillus or just the American Standard type fixture?
    I am guessing that perhaps only American Standard or American Standard Amarillus uses the step down stem identified in the photograph. From what I am seeing on the net, those are not cheap faucets. I am guessing somewhere around $600.00 just for the bathtub.
    Are there any other manufacturers that use the step down stem? As I mentioned in an earlier post, I do not want to tear up my walls having to replace the fittings on the pipes.
    Default A/s
    The stepped down stem helps identify it. It has nothing to do with whether some other make or model would work with it. That is a function of the diameter of the stem and the number of splines on the stem. An additional restriction is the escutcheons and they way they attach to the faucet. ALL of these pretty much preclude using anything other than parts from American Standard, and also implies that only Amarillus trim will work.
    Thanks again for all who have helped me solve this issue. Now I need to find out who sells the American Standard Amarillus bathroom faucets in the Pittsburgh area.
    I will be reading posts on the website while I ramp up for my overhaul of the bathroom down in the basement. I want to add a shower but do not want a professional due to the fact that I must get a permit and then allow the inspector in the house and then my taxes go up.
    All I need is the shower frame and some plumbing. I can do the water lines. I am not sure on the drain and how high the shower floor should be. An upstairs drain is right behind the wall and it is a 4 inch PVC drain. It goes straight into the basement floor. My cousin will put up the walls and tiles for me.
    Did you try HD at Ross Park? or Plumbers Equipment on Babcock?
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Default Leaky american standard tub/shower valve
    ON THE INTERNET GO TO THE FOLLOWING LINK
    http://www.m-onespecialties.com/contact.asp
    THEY SHIP ANYWHERE OR MIGHT ? BE ABLE TO TELL YOU ABOUT SOMEONE IN YOUR AREA
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Tim,
    This place might be a possiblity.
    Masterpiece Kitchen and Bath, 724.452.5088
    Cookie
