Results 1 to 14 of 14
Thread: DPST switch question
    IT Consultant / Network Engineer beekerc's Avatar
    Oct 2008
    Seattle
    Default DPST switch question
    are the two circuit lines in a double pole, single throw (DPST) switch electrically isolated? specifically, could I run A/C across one line and D/C across the other?
    here's my application.
    i have a garage door openers. in the old days, when i would go on a trip, i'd unplug it from the wall so as to prevent the doors from being opened by accidental or intentional remote signals. with my current openers, I have hard-wired the openers, so instead of an A/C plug, there's a SPST switch in the wall to cut power. the issue is there's a battery backup in the unit which is great for power outages,but if i wanted to really kill power to the unit, i have to climb up and disconnect the battery as well. what i'd like to do is run some low-voltage wire from the opener to where the A/C switch is and install a DPST switch so i can cut the A/C and disconnect the battery with one switch.
    is this feasible to do?
    are there any NEC issue with putting a D/C circuit and an A/C circuit on the same switch (even though the poles should be isolated)?
    yes, i know with modern openers and rolling codes, it's highly unlikely that my door could be opened by a rogue transmitter, but i'm old school when it comes to security - no power, no open.
    thanks
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by beekerc View Post
    Yes, as long as the switch contact load ratings are sufficient. For a given contact lifetime, it's easier to switch a given amount of AC amps than DC amps because the alternating current goes through zero 120 times/second.
    Ratings are for motor/inductive load, tungsten (lamp) load and resistive load. A common wall switch rated at 15A could be rated at 12A for a motor load.
    You shouldn't have high and low-voltage circuits in the same box even though the switch will handle it. Adding a loop to DC circuits will add resistance, and likely require increasing the wire gauge to maintain low voltage drops, so take that into consideration if you put in a separate switch for the low-voltage circuit. FWIW, some openers have a 'vacation' switch that essentially disables the RF section. With the newer rolling code, multi-billion possibilites remotes, somebody hacking into the system to open the door is really hard to do, and if they can do that, they'd get in one-way or another anyway.
    Aug 2008
    MD
    With a single switch and relay(s) you can keep the hi/lo separation and still make your design work.
    Coming at it from the other end, find out how to comply with the NEC and then we'll design circuitry to meet your desired function.
    One possible way: the relay that cuts battery power can have a 120vac coil or a 24vac coil. If it has the low voltage coil you need to switch on and off a 120v:24v xformer.
    These parts are all available from Hosfelt.com for a few bucks.
    An energy saving design would be to just use two separate switches. One for AC and another for battery. Then zero electric use when off.
    I don't know about you, but I'm getting fed up with "parasitic loads". Everything you buy these days is "always on" and always using a little electricity. All these things add up.
    Here is more on this...
    Leaking Electricity: Individual Field Measurement of Consumer Electronics
    http://enduse.lbl.gov/info/ACEEE-Leaking.pdf
    Aug 2008
    MD
    Quote Originally Posted by Billy_Bob View Post
    The product marketing people have decided that the consumer's utility for "instant" is more than his/her disutility for wasting some power.
    They're probably right; everybody wants instant nowadays. These people would not have been able to withstand the vacuum tube and no-cell-phone era.
    Default door
    Why don't you have a wall switch with the "off" circuit that kills the radio receiver and only allows the wall switch to open the door?
    Aug 2008
    MD
    Verily, Sire.
    It seems that there is more than one way to skin a cat.
    Listing all possible options as a first step is what Decision Theory recommends for solving these type problems.
    Oct 2008
    Seattle
    agreed, but while i do take advantage of may high tech security options, some habits just die really hard.
    i'm now thinking may be i should go with a single-gang, dual-switch device, then maybe use some plastic and glue to tie the switches together, so it acts like a double breaker. sure, there's both high and low voltage coming into the same box, but at least the circuits are isolated.
    i'm pretty sure the RF receiver is integrated into a circuit board somewhere, being able to put a switch to interrupt its function would probably require some serious "surgery".
    Quote Originally Posted by Thatguy View Post
    this wouldn't work. if i understand how relays work, as long as there is 120v flowing through the relay, it closes the circuit that the low voltage circuit. if a/c power is cut, then it breaks the d/c circuit. is this correct?
    the only problem is that if the power goes out, then the relay would kill the battery backup. i only want battery backup cut when i flip the switch manually.
    Aug 2008
    MD
    You can have it either way, with Normally Open or Normally Closed contacts.
    http://www.rowand.net/Shop/Tech/imag...iringGuide.jpg
    The relay doesn't know if he flipped the switch or if it's a power outage.
    Why not just a pad lock through the holes on one of your tracks so the rollers can't move?
    Aug 2008
    MD
    It begins to sound like this problem is unsolvable, and that is not possible.
    In the Trades killavolt's Avatar
    Apr 2009
    Southington CT
    Quote Originally Posted by manny1602 View Post
    That's what I do...keeps the motorcycle safe when I'm away.
    Default door
    EVERY electric door motor, and wall pad, that I have had since 1977, has had a lockout circuit on the pad to cut out the radio receiver circuit and ONLY allow the wall pad to operate the door. How old is your operator?
