Could be coming from any of those.
Unless you get rid of the water you can't solder.
I consider myself a savvy do it your self guy. My 10 year old house has a leak where the 4 cold water pipes come up from the slab and join together in the hall. It's a the sweat joint of a "T" coupler. I'm having trouble getting the water out of the risers. I tried opening all the water valves in the house and using a powerful shop van on all outlets thinking I'd get enough to form an air pocket. I also tried closing all but two to clear a single end to end trac of pipe. Seems like the kitchen faucet has a check valve and won't let me suck from there?
Could I be siphoning from the hot water tank in a reverse flow? Just can get it hot enough to solder.
HELP!!
Almost every rule has an exception, but this is one rule that in unforgiving. No water mean exactly that. You may have to cut somewhere else in the line so as to be able to drain the pipe. If you have compressed air, that might work, sort of the opposite of the shop vac. You just have to figure a way to get the water out.
Is there a lower point anywhere that you could open to drain.
Even if it's a connection in the meter box.
One more important question.
The leak was almost less than a drip. It had been closed up an unable to evaporate and cause the wood floor to warp. It had been leaking for some time because there is calcium running from the joint. I cleaned it with a steel wheel on a dremel. Will I be able to re-solder?
Again. with it open to air, it evaporates quicker that in can form enough to drip. Would there be too much calciun "IN" the joint to re-solder?
Thanks again, YOU gus are great!!
Clark
From Tulsa, Ok.
Ron Hasil Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning
Sump and Ejector Pumps | Backflow RPZ Testing
I totally respect SewerRatz advise. Does everyone agree I shouldn't resweat?
I'm afaid that proceedure would open a can of worm and no longer be a DIY.
See all those pipes coming up are only 9 inches off the floor... 4 cold water pipes are concentrated only inches apart from eachother.
If I called a plumber would he cut all 4 and have to rework all just to fix one?
Probably not.
It does sound like a plumber would be a good idea for you.
I was taught that if a joint leaks, once water has gotten into the leak the joint is contaminated plus there is no way to get flux into the the joint so resolder is impossible. Not sure of the actual truth of that, but I sure never try to resolder a bad joint. It's too easy just to start over. I have saved a fitting upon occasion when it was the only one I had on hand and nothing was open to get a new one, but normally I toss the old and use new.
Post a pic, maybe that will help with an easier approach.
Once I had to keep the shop vac sucking through a 1/4 copper line that passed through the joint I was soldering. Couldn't access the 2nd floor to drain line right.
I too believe this will be the case.
You might find a compression tee that you could install even with water in the pipes. If you can pull the pipe hangers off to get some movement you might have the option to cut out the faulty tee with a hacksaw, right at the hubs, clean up the ends of the pipe and install the compression tee.
Okay, Here the pipes in question. There is actually two leaks that leak so slow that the water eveaporates before a drip can form and fall or run.
However, when the wall was all closed up, there was condensation build up big time. You should be able to spot the joints in question by the burn marks. Also note the joins in question are dark color because I burned the flux trying to re-sweat them. Just couldn't get it hot enough. See earlier comments I made in this thread.
I would suggest once again hiring a plumber for this task.
Does seeing this give you the thoughts that the joint needing re-sweating are going to force a rebuild of the entire junctions (cut off all 4 left cold water and 3 right hot water). I think you're right if that's the case. I may just call in a plumber. What should I expect to pay to fix this issue?
