Results 1 to 9 of 9
Thread: Washing machine venting
    DIY Senior Member Rich B's Avatar
    Sep 2008
    New Jersey
    Default Washing machine venting
    I have two washing machine drains to plumb and vent. I am upgrading them to the proper size 2" using wyes into a short 4" horizontal C.I. section. I can go straight up with a vent. The two washer drains are seperated by a block wall in the basement, as this is a 2 family house. Can I use 1-1/2 for the vents, go straight up and join the two together in the common wall above? From there it would join with a common vent for one of the bathrooms upstairs. A tub and a sink....then up thru the roof and increased to 2"....The existing washer drains had no vents and are 1-1/2" and are poorly done in galvanized pipe.
    Nov 2006
    I believe what you have planned will work fine, but a real plumber will have more insight as to codes.
    Default vents
    One thing about the common wall between units, is that it may be considered a fire wall and, if so, any penetrations should be made and sealed with fire resistant materials.
    Dec 2005
    SW Florida
    Under my codes, once you connect the two vents together you'll need to be at 2" for the vents.
    What is your location or what codes are you under?
    A sketch or picture would likely help further.
    Matt
    Enjoying life in SW Florida
    Jul 2008
    S. Maine
    Which code is that?
    Dec 2005
    SW Florida
    Quote Originally Posted by nhmaster View Post
    Which code is that?
    Florida Plumbing Code 2007, based on IPC.
    Common, wet and/or waste stack 1-1/2" Vent is only good for 1 dfu.
    Also under FPC the min vent for 1 clothes washer is 2".
    Matt
    Jul 2008
    S. Maine
    Me thinks you have mis-interpreted the IPC. You can wet vent an entire bath group off an 1 1/2 pipe.
    Dec 2005
    SW Florida
    I may have. I only have the FPC, the foreward in the FPC indicates its basis on IPC.
    FPC2007 Table 909.3
    Wet Vent/DFU=
    1-1/2"/1 dfu
    2"/4 dfu
    2-1/2"/6 dfu
    3"/12 dfu
    Matt
    DIY Member techinstructor's Avatar
    Apr 2009
    North Carolina
    Quote Originally Posted by FloridaOrange View Post
    FPC2007 Table 909.3
    Wet Vent/DFU=
    1-1/2"/1 dfu
    2"/4 dfu
    2-1/2"/6 dfu
    3"/12 dfu
    North Carolina code is similar to FL.
    Table: 908.3
    1/1/2"/1 dfu
    2"/4 dfu
    2 1/2" to 3"/6 dfu
