Results 1 to 5 of 5
Thread: Soiree MaP scores?
    Question Soiree MaP scores?
    Hello,
    I am thinking of purchasing a Toto Soiree or Eco Soiree, but cannot find info on MaP flush scores. Does anyone know what the scores are?
    thanks!
    TOTO never sent the Soiree model for testing.
    I've sold 89 of the Soiree and Guinevere toilets since they came out.
    They have worked out very well.
    Many of the customers started with one, and then bought more.
    Either would be a safe choice.
    DIY Senior Member SteveW's Avatar
    Feb 2005
    Omaha, NE
    Be aware that the Soiree requires the Unifit adapter, which may mean relocating your water supply.
    I have a Soiree and 2 Gwyneths. I highly recommend the Gwyneth. No messing around with the Unifit water supply issues, and at least in my house the flush quality is much better for the Gwyneths - rarely if ever have to double flush to clear the bowl, but often need to with the Soiree.
    The Soiree and the Guinerver need 5-1/2" center to center or more for the shutoff.
    The Toto spec does not show what you can get by with, it shows a generic measurement that would work on any toilet.
    Terry Love
    Thank you for your responses and for pointing out the water supply issue. I had not realized that. I guess i would need to move the water supply out more. it is currently offset 5 inches and according to the diagram for the Soiree, I need 5-1/2" center to center. So i take it that the Soiree wont fit.
    I will need to pick a different toilet then.
    The Gwyneth seems great but it requires more length and would be a bit tight for my space.
    Terry Love
    The Soiree, Guinevere and the Gwyneth are about 28" long.
