Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: Lavatory pop up drain
  1. #16
    Aug 2008
    btw, pbr3232, the most proper way to replumb your setup is with a loop vent.
    I just post cuz I like to see my avatar.
  2. #17
    Dec 2007
    Quote Originally Posted by kingsotall View Post
    No because those are only allowed on island sinks.
  3. #18
    Dec 2007
    Quote Originally Posted by SewerRatz View Post
    Yea I decided to at that note... I rather see an AAV than what is there.
    OMG tear my eyeballs out!
  4. #19
    Jul 2007
    USA
    There is no way a Milwaukee 15 amp would get through that pipe.
    Still have not tried mine out yet...
  5. #20
    Plumber Cass's Avatar
    Follow SewerRatz suggestion and it will make your plumbing system happy and your job easy...Redwood...Does CT allow AAVs...
  6. #21
    Nov 2008
    Chicago, IL
    lol.. I know I think I am getting soft in my nearing the old age. When I am as old as you guys I be telling people to go ahead and use pex, and sharkbites.
  7. #22
    Aug 2008
    And wax rings!!
  8. #23
    Nov 2008
    Chicago, IL
    And wax rings!!
    Ok your pushing your luck there buddy. I would never tell anyone to use a wax ring.. wait if you dig though my posts you see I did say something about a No. 10 wax ring... Damn. I am turning into a hack.
  9. #24
    Default drain
    quote; No because those are only allowed on island sinks.
    __________________
    NOT TRUE, because it can also be used when the sink is on a wall which has windows above it and posts at either end, precluding ANY common vent configuration, OR in a knee wall which is not an island. BUT in this case it would be a Draconian situation requiring extensive remodeling. The proper solution is to cut out that kludge and install a proper drain configuration, even if it requires a properly installed AAV, and "properly installed" is the key phrase.
  10. #25
    Aug 2008
    I have seen many loop vents installed in situation described by HJ. Doing some reading on island/loop vents and it seems that both IPC and UPC have very strict guidelines in regards to them. It might be wise to look into the requirements.
