Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: Lavatory pop up drain
    Default Lavatory pop up drain
    I have a lavatory pop up drain that is in sink that is siliconed to the counter. The pop up tail piece goes into a trap adapter that is glued onto a piece of pvc into a drum trap. The idea is I can't remove the trap or drop the trap adapter to give some slack to remove the drain assembly. I am jammed between the sink and the trap adapter. How would you remove the pop up drain assembly and put a new one in without having to lift the sink off.
    Thank You
    Peter
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    Sawzall time!
    Or "tiny tim" or hacksaw or tubing cutter...
    I just post cuz I like to see my avatar.
    You can cut the old one. How about putting the new one in.
    Peter
    Aug 2008
    This is taking it a bit far but would work. Drill two hole through the pipe so you can stick a screwdriver in it and use it for torque. Obviously you have used pipe wrenches and channel locks to no avail, I assume.
    Appreciate your response but I think we are talking two different thing. I was wondering how you replace a pop up drain assembly when you can't remove the trap because the trap and trap adaptor is glued and there is no slack and the lav is siliconed down. I could pop the lav up install the drain and silicone it back.
    Peter
    Nov 2008
    Chicago, IL
    I picture would be helpful.
    Here is a photo I hope.............
    Nov 2008
    Chicago, IL
    I can already hear what everyone else is going to say.
    It will be in the lines of cut out that drum trap, and replumb that drain line with a tee, atop of that tee put an AAV, and on the tee branch install a trap adapter and a p-trap.
    Apr 2005
    What city and state is this in.
    It's in an area where drum traps are illegal. But it is existing so whether it a drum trap or an s trap it okay. I just want to change the pop up drain. If you are jammed you are jammed whether it be pvc or a galvanized drain pipe. I will just pop up the sink.
    Peter
    Dec 2007
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Default Lav. Pop up drain
    IT IS VERY EASY CUT THE 1 1/2" PIECE BETWEEN THE 9O AND TRAP,
    CHANGE OUT YOUR POP UP ASSP. THEN USE A PRO CLAMP COUPLING TO RECONNECT THE PVC
    http://www.fernco.com/img/products/p...gs-proflex.jpg
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Nov 2008
    Chicago, IL
    Quote Originally Posted by pbr3232 View Post
    Peter
    I bet it was illegal before they allowed PVC and before they started to make PVC drum traps. Also most codes only allowed drum traps to be used with bathtubs.
    What MACPLUMB 777 said is true very easy to cut below the elbow and fernco it back in with a shielded fernco coupling.
    But its just as easy to repipe the PVC by cutting below the 90 glue in a sanitary tee a short pipe on the run with a trap adapter, and an AAV on the top of the Tee. See below image I stole from Redwood. I mean why keep it the way it is, when you can easily correct it and make it a whole lot better than what you have now. I normally do not recommend the use of AAV's I am in an area that requires proper vent piping.
    Aug 2008
    SewerRatz, is that really you Suggesting AAV's
    edit: Oh, ok.
    Last edited by kingsotall; 04-24-2009 at 09:12 PM. Reason: cuz SewerRatz edited his
    Nov 2008
    Chicago, IL
    Quote Originally Posted by kingsotall View Post
    edit: Oh, ok.
    Yea I decided to at that note... I rather see an AAV than what is there.
