Try this; turn off power to switch, drain tank (relieve any water pressure), remove switch and conecting tube and clean any crud build-up. While your at it with the tank empty of water, check the psi in the tank to 2 psi below the pump's cut-in setting.
If after doing this, the pump still will not shut off, the points may be pitted (burnt). then its best to replace the switch.... $ 10.
