Results 1 to 6 of 6
Thread: Using Unions
    DIY Senior Member BimmerRacer's Avatar
    Jan 2009
    Washington, DC
    Default Using Unions
    Is there a better way to make this type of connection? I read that some locations disallow unions behind walls, I am not certain on laws here. I also read that unions are more leak-prone.
    I also read that using a reverse threaded fitting would eliminate some of these concerns, but can't seem to locate one, perhaps I am searching for a wrong thing.
    Default unions
    YOu must be anticipating problems, otherwise the tubing would be attached directly to the manifold. If unions were no allowed inside walls, there would be several million tub and shower valves, installed since the earliest days, which could not have been connected, because they ALL had union connections.
    Jan 2009
    Washington, DC
    I am not anticipating anything, this is a stock photo from Kohler. The servicability of the digital valve however is a potential issue.
    Dec 2007
    Quote Originally Posted by BimmerRacer View Post
    Oh you know it!
    I dread the day I get sent to fix one...
    I'm just so not interested.
    Jan 2009
    Washington, DC
    I hear you on that, but the same principal applies to any valve I would think, digital or otherwise.
    Dec 2007
    It is indeed a very complex mousetrap that Kohler has designed...
    I look forward to their many modifications, discontinued parts and long waits for back ordered items.
    http://www.us.kohler.com/onlinecatal.../1043183_5.pdf
    http://www.us.kohler.com/onlinecatal.../1043183_2.pdf
    http://www.us.kohler.com/onlinecatal.../1043184_2.pdf
    http://www.us.kohler.com/onlinecatal.../1043184_5.pdf
