Results 1 to 5 of 5
Thread: Fire Hazard? Expanding Foam - Electric Boxes
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Fire Hazard? Expanding Foam - Electric Boxes
    Is there a fire hazard created when you put expanding foam around electric boxes? What, if anything, is safe when using the foam around a box?
    Thanks for any replies
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    Supposedly foam is fine around boxes. Just make sure all holes are sealed so the foam does not enter the boxes.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by Speedy Petey View Post
    In that case heat dissipation from the box due to IČR loss and bad wirenutting/connections depends on heat conduction through the copper and the cover plate being at room temp. I guess the NEC has already figured the boxes would be insulated with no air flow around them.
    Jun 2007
    NY State, USA
    I have never heard of "heat dissipation" around electrical enclosures being an issue.
    A failed connection just need to be contained for safety.
    I would say the NEC definitely has considered this assuming many boxes and enclosures are on exterior walls and ceilings.
    Aug 2008
    MD
    I guess that means that enclosures have, or the air in them has, never gotten to 120 °C
    "Wood slowly chars [at] 120°-150°"
    but failed connections certainly have
    "Electrical arcing [up to] to 3750°[C]
    I guess air is pretty good thermal insulator.
