Thread: Bend In Bathroom Venting
    Default Bend In Bathroom Venting
    I just had my roof done and had the roofer switch a bathroom exhaust from venting into an attic fan to a dedicated vent. I'm sure the attic fan solution was fine when the fan was one, but that's only about 10% of the year. The new vent was place about 4 feet from the attic vent and gap was coverend with flex tubing, like you'd use for a dryer, and that tub was about 6-8 feet in length so it creates this large U. Should I be concerned?
    Thanks for the feedback.
    Dec 2007
    It will probably accumilate condensation in the colder months.
    Default U
    If the "U" is downward it is bad, if it is horizontal just to change direction, no problem. But why a "U", and not just a gradual turn into the correct direction?
    Default The 'U'
    The original vent pipe was rigid and most of it is still there. They added flex pipe to cover the distance between the old rigid pipe and the new roof vent, but apparantly had too much length. It now hangs down just about as far as it travels to the side to get to the new vent forming a 3 or 4 foot 'U'.
