Wirsbo (Uponor) fitting difference?
Rad777
What is the difference between Q4505050 & Q4515050? Respectively Brass Fitting Adapter versus Brass Copper Pipe adapter.
Q4505050-ProPEX-Brass-Fitting-Adapter
Q4515050-ProPEX-Brass-Copper-Pipe-Adapter
The reason I ask for the difference is because I was thinking about how to transition from PEX to Copper -> Valves and/or directly to Valves from PEX.
Are these fittings something I could just sweat a valve onto?
Thank you
SewerRatz
Illinois Licensed Plumber
Chicago, IL
www.a-archer.net
At first glance, the difference I seen was 5 cents :D
Seriously, the Q4505050 fitting looks like a male sweat fitting meaning it will sweat in to a fitting like a tee. The Q4515050 looks like a female sweat fitting meaning it will sweat on to a pipe.
Rad777
Thanks for the replies & help!
Still deciding if I am going to Pex all the way to the fixtures/valves, or if I am going to transition to copper and attach it to a stud or a 2x4 horizontally betweeb studs.
Kingsotall
Plunger/TurdPuncher
Flagstaff, AZ
I would recommend stubbing out with copper. A drop ear fastened to some blocking makes for a very sturdy pipe to connect stops and showerheads to.
Check out this link for some ideas.
Rad777
Thanks for the recommendation and the advice. I read a few posts by Terry mentioning that practice as well and I think that is what I will use/do.
