Results 1 to 4 of 4
Thread: Propane to electric
    Default Propane to electric
    Hi,
    I am redmodeling my kitchen where I have a propane gas range. The flexible copper tubing comes throught the floor to feed the range, for some reason there was never a shutoff valve installed; not good. I need to cap of the line before I can do any more work on the kitchen. I bought a flare cap to put on the brass 90 degree elbow that is attached to the flex copper coming up through the floor. Will this work? Do I need to use a copper washer or bonnet with the flare cap to get a good seal?
    I am going to buy an electric range, so I don't really need the gas line anymore. Should I cap it off a the tee in the basement instead of in the kitchen?
    Any help appreciated...
    Feb 2005
    Talking do in the basement
    their are a number of ways I can think of that can be done in the basement, I would not just t a flare cap in the kitchen...
    Default propane
    Remove the tee and replace it with a coupling/union.
    Smile
    replacing the tee makes sense...no capped ends that way
    thanks
