Results 1 to 14 of 14
Thread: old fashioned galvanized tub drain cleanout
Hybrid View
    General Contractor danceswithhammer's Avatar
    Apr 2009
    seattle washington
    Question old fashioned galvanized tub drain cleanout
    I have an old galvanized plumbing system with a tub attached to a drum shaped trap of some kind with a plug that unscrews mounted in the woood floor adjacent to the tub. I assume this is a p trap of some kind. It was probably installed in 1937. Should I keep this or figure out how to remove it and replace with conventional ABS p trap and new drain and overflow? The existing drain and overflow leaks, is corroded, and drain is slow.
    Nov 2008
    Chicago, IL
    You can change the waste and overflow with out the need to change out the drum trap. I keep the drum trap as long as the plug comes off and the threads in the trap are still good to make a water tight seal when the plug is installed. To clean the drain you remove the plug on the trap and rod the line back to the tube and towards the main drain, usually no more 10 feet away.
    Yakima WA
    I agree with Sewer Ratz, but if you every do a remodel, get rid of both the galvanized pipe and the drum trap. Those traps are way outdated.
    Nov 2008
    Chicago, IL
    I bet you would say using plumbers putty to set a water closet is outdated too.
    Dec 2007
    Quote Originally Posted by SewerRatz View Post
    Who wouldn't!
    Default yes
    Sewerratz. See what association with us is doing? You are getting smarter already.
