gas pipe sizing
Sulconst2
old bridge nj
hello all.
new to the site. hope to get a question answered quickly as i'm in the middle of an addition.
installing a 90,000 btu furnace into an addition. calls for 82 cubic feet per hour. have a 50' branch run from meter. according to chart it should be 3/4"
my question is can i run 30' horizontal of 3/4" ips then reduce to 1/2" for my vertical run of 20' to the unit? or do i need to run 3/4" the whole way?
thanks in advance
Master Plumber Mark
www.weilhammerplumbing.com
gas pipe
honestly, if you are running black pipe,
its usually best to do the max go 3/4 all the way
......because if you or the next owner might want to add a gas
water heater or other outlets someday it would
not be a big problem...
I myself would run it out of 1 inch black pipe
and reduce it down to half inch once you have gotten
into the mechanical room. putting a tee and a cap
in the line for future needs if any would arise.
it might sound like overkill,
but it dont really cost that much more
at least do the 3/4
