Results 1 to 12 of 12
Thread: Your vote is needed
    Jul 2007
    USA
    Default Your vote is needed
    After the sawzall and the replacement window arrives, one of the first things I will need to do is "remove the glass". I assume I should just smash it.
    Which tool shall I use?
    1) Name:  IMGP1488.jpg
    2) Name:  IMGP1489.jpg
    3) Name:  IMGP1490.jpg
    or 4) Name:  IMGP1492.jpg
    It probably isn't worth trying to save the glass, but smashing it will create some safety and cleanup issues.
    If you scrape the putty away, you may just get them out fairly quickly and easily. A torch to soften it first might help.
    If you decide to smash it, the first hammer with the fairly small pointed side will do it easier.
    Wear good gloves and eye protection.
    Default glass
    The glass in in the movable panel. Remove it first, without breaking the glass, because you have to do it anyway to cut the frame out. Are you sure you have the abilities to do this?
    In the Trades jnaas2's Avatar
    Mar 2009
    Evansville In
    The first thing to do is make sure that the window will fit, There is nothing like taking something apart only to find out the parts wont fit
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    My vote.
    Guess my post count can thank you.
    Jul 2007
    USA
    Thanks guys. I am just trying to get all the tips I can before I try this.
    Of course I will wait for the window to arrive too and check it fits as best I can before removing the old one.
    These windows are rusted shut though so everything will need to be cut out. I'll try to chip away at the putty to remove the glass.
    If all else fails, I will board up the window and call a pro. I have five of these windows to do and will take them on one at a time. If it gets too much, I'll quit.
    Jul 2007
    USA
    Would it be worth taping the window first?
    Feb 2005
    Talking Why not have some fun with an auto shotgun...
    Remodel Contractor GabeS's Avatar
    Jan 2007
    Brooklyn NY
    Don't try to remove it without smashing it. That's no fun.
    I got a better idea. Think back to when you were a kid. Stand outside, grab the biggest rock you can find, and throw it right through.
    If not, then go with tool number four because it will give you the longest distance between you and the window. Wear good gloves and goggles.
    Gabe
    Don't follow my advice, I only know a thing or two about a thing or two.
    Default glass
    A 20mm rocket laucher under a M-16 would do the job and might also remove the metal frame at the same time.
    Jul 2007
    USA
    I am still thinking about this. The replacement window(s) have not arrived yet. Tried the Milwaukee out on a bush that's been bothering me though.
    The Milwaukee won.
    My father-in-law suggested a glass cutter and then duct tape for the glass.
    Jan 2008
    I wouldn't sweat it. Put down a sheet of plastic outside to catch the pieces and hammer away. I'd go with #1, 2, and 3, slowly and deliberately. Gloves and safety glasses are a must.
