Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: PEX certification?
    Default PEX certification?
    Has anyone had any experience with getting PEX certification as a non-professional?
    I'm replacing copper lines with pex (I am the home-owner). My local code states that the pex has to be installed by a factory-trained installer; apparently I need some type of training & certification.
    My inspector had thought that the retailers were obligated to offer this training but I posed the question to a few of the local retailers and got that wonderful blank-look I've come to know so well from them...
    I'm really surprised that I need this training for Pex when, apparently, I wouldn't need it for copper installation. But, I've got the code in front of me right now & the requirement seems very clear.
    I'm going to keep researching this locally to see if I can find an answer, but I thought I'd throw it out here to see if anyone else has had any experience with this.
    thanks!
    Thanks for the reply!
    A couple of follow-up questions:
    1) As a non-professional, am I eligible for this type of training?
    2) Is certification issued based on a manufacturer-specific basis? Or is there training available for general pex installation?
    (I guess what I'm getting at with this last question is, as a professional, are you certified to use all pex manufacturers' products or do you only use one manufacturer because that's the one you're certified with?)
    ...aside from my current project, this is just interesting stuff to learn. Trudging through this project makes me think I should've chosen a different path in life & become an "actual" plumber. (Too soon old, too late smart.)
    thanks again!
    Dec 2007
    Quote Originally Posted by MN-E View Post
    Inquire with Uponor
    Uponor and others issue manufacturer based certifications.
    No I was certified Upohor/Wirsbo but changed to another brand a few years back.
    thanks again!
    I believe Viega also has certification classes.
    Default Pex
    Being "eligible" for certification, and finding a source to get it could be two different things. The majority of certifcation classes are given by each material's representatives at wholesaler sites. These sites deal with licensed contractors and thus may not wish to be put in the position of training the very people who the contractor would be selling their services to, thus undercutting them.
    Jul 2008
    S. Maine
    Whatever state or city you are from has just become my hero.
    thanks!
    What you are caught up in is a trade protecting code. And a supposedly DIY forum populated by some very adamant trade protecting plumbers.
    It has nothing to do with the material being used for potable water systems as long as your PEX is stamped NSF Standard 61; it is approved. BTW, most PEX manufacturers do not require that so the code is questionable IMO because it supports one brand of PEX over all the others without the training or requirement.
    The manufacturer requiring only approved trained by them installers is a CYA thing on their part and more trade protection while being the only one able to meet your state's code.
    As you say, there is no training type code for installing copper (or PVC, CPVC, galvanized, or PE pipe), so if it were me, I would install the PEX with the manufacturer's fittings etc., or buy a different brand, and tell the inspector that if he can't find something wrong with the system leaking or being supported properly (like every 3-4') etc. to approve it or not, and I'd get on with my life. And I'd fight if need be because of that frog in a pan of ever increasing hot water thingy.
    Yeah... getting an attitude with my inspector seems like a good way to burn bridges and make things more difficult for me.
    The code is written the way it's written, and I just want to do a good job. Much like the law: I might not agree with it, but I'm going to obey it.
    Now, I am kind of irked at the retailers for not even knowing about this when they sold it to me, but it is what it is.
    Dec 2007
    That is correct!
    However the code is what it is and it must be obeyed.
    I would check the code and see if indeed the inspector is citing it correctly.
    If he is the only thing to do is lobby for change.
    I would call it a DIY Forum populated by plumbers who believe if the job is not going to be done right, a plumber should be hired to do it right.
    Also some of us believe there are jobs that are best left to be done by a plumber. Particularly those that are ones that done incorrectly might turn a house into a smoldering pile of splinters in a heartbeat, or, cause an entire family not to wake up in the morning...
    Gary, Do you have a problem with that?
    I applaud you!
    The law may also weed out PEX of lessor brands.
    Kitec, Zurn have had clasa action lawsuits and a few others are heading for one. (Dura-PEX)
    None of these brands have certification classes...
    Heh... there's the grind I'm running into right now.
    I started working on the project before I found out about this "certification" requirement (dumb, rookie mistake on my part). Basically, I've got the majority of my PEX rough-in done at this point, but I just found out that I need this certification.
    AND... guess what kind of PEX they sold me at the Home Depot?
    Yep. Zurn/QestPex.
    Crud. I just found out about the class-action against them while I was researching the certification today. Now, do I tear out what I've done because this stuff might be junk? To add to the problem, the other easily-obtained PEX in my area is Nibco. Now did I hear correctly that they've got a suit pending against them, too?
    By the way, Zurn DOES offer a certification program... I just need to go to Erie, PA to take the class. Not a casual trip from here in Minnesota.
    Criminy, this ain't easy. If my wife doesn't leave me over this whole drawn-out mess, it'll be a miracle.
    Jul 2008
    S. Maine
    You Will Obey
    Dec 2007
    Well the tubing isn't the problem it's the fittings...
    You could always get certified in a better brand and use the fittings from that brand...
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Quote Originally Posted by nhmaster View Post
    you will obey
    rotflmao.:d
    Aug 2008
    Fairfield Co.,Connecticut
    Gary:
    What's the big deal about taking a quick certification course? Why get worked-up fighting city hall? Watts had me take a 10 minute certification course and the other supply house wouldn't sell me the worsbo tools unless I had the certification ... no big deal. I decided to use pureflow (viega) and that didn't need a course. I see no problem insisting that someone become educated before installing their product.
    Nov 2008
    Chicago, IL
    There is training its called an apprenticeship, 5 years to be exact along with 4 to 5 years of schooling.. Here in Illinois you must be a licensed plumber to do any plumbing remodeling and major repairs. The code does allow for a non-license individual to do minor repairs. And this definition is from the Illinois Plumbing code book.
    "Minor Repairs": Repairs that do not require changes in the piping to or from plumbing fixtures or involve the removal, replacement, installation or reinstallation of any pipe or plumbing fixture.
