Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Price Phister AVANTE, removing mixing valve cartridge
  1. #16
    Hello Braden,
    Thanks for posting your question here. We would like to help address this issue quickly, but our Consumer Service Team needs some additional information to proceed.
    Please provide:
    * The model number of the product. If you do not know this, please follow these directions: http://www.pfisterfaucets.com/do_it_...lf/how_to.aspx
    * Any other specifics on the issue you’re experiencing
    * A method to contact you (ex. email, phone, etc.)
    * Best time for contact (ex. mornings, evenings, etc.)
    Please send this information to us at pfistersocial@bdhhi.com.
    We apologize for your inconvenience and look forward to resolving this matter as soon as possible.
    Sincerely,
    The Pfister Team
    Pfister is a part of the Stanley Black & Decker Hardware and Home Improvement (BDHHI) Group.
  2. #17
    DIY Junior Member ak99588's Avatar
    Jun 2011
    Copper Center, AK
    Default Having Trouble Removing Valve
    Hello. I'm hopping on this thread because I have the same valve and I'm having trouble getting the cartridge out. The photo shows my tub valve. I reinserted the handle screw and using a vise-grip tried pulling, yanking, twisting, and wiggling but it will not budge. Any suggestions from seasoned veterans?
    [ATTACH]13375
  3. #18
    DIY Junior Member TexasUltra's Avatar
    Apr 2009
    S.W. Houston, Republic of Texas
    Name:  shower valve.jpg
Size:  39.6 KBOK, it's me again.
    Same faucet, only this time the stem broke off and remained in the knob. Any advice on removing the cartridge remaining in the valve body without the stem?
    How do I find a quality replacement cartridge?
    Are the two slotted screws on either side of the valve body for shutting off the water?
  4. #19
    INsert a screw into the remaining stem and THEN perform the previously stated extraction method, i.e., grab screw with pliers, push stem in, the pull out VIOLENTLY, maybe several times. Those are shut off valves.
  5. #20
    Apr 2009
    mission accomplished, the only glitch was the (LASCO) stem was hollow, a little smaller than a 5/16 bolt. I ran a 5/16 tap in it and gave the t-handle a tug and bam! old cartridge out. Replaced with PHISTER from MORRISON SUPPLY this time. This is probably one of those get what you pay for lessons I have such a hard time learning.
    DIY Junior Member notaplumber1's Avatar
    Nov 2013
    Minnesota
    Default Price Pfister Shower Identification
    Had a shower valve that failed and started spraying water on me. I need to identify it so that I can get a replacement part. On the valve it says SHWR 7106. I found a thread that discusses this with a replacement part (S74-292) but not sure if it will work as well.
    http://www.terrylove.com/forums/show...tion-PP-Avante
  7. #22
    (Price) Pfister Avante stem is the replacement.
  8. #23
    DIY Junior Member plumbstar's Avatar
    Aug 2012
    Lomita, CA
    I don't like pulling hard on the entire valve assembly as it may not be anchored well. It can also affect how well the spout is sealed.
    What I always do is:
    Remove retaining nut.
    I then use a channel lacks sideways.
    I place the cartridge shaft in the inner portion of the jaws, positioning the end of the jaws against the valve body.
    Using the valve body for leverage, while holding the cartridge shaft securely, I gently pull the shaft out with the pliers.
    Never had it fail nor does it damage the valve body threads
  1. Price Pfister Avante. How to remove a stem from shower?
    By templeavenue in forum Shower & bathtub Forum & Blog
    Last Post: 08-16-2013, 01:04 PM
  2. Kohler 401 Mixing Valve Cartridge Repair or Replace?
    By jsmabrey in forum Shower & bathtub Forum & Blog
    Last Post: 11-18-2012, 01:45 PM
  3. Price Phister Bath/Shower Valve part
    By gbarry in forum Shower & bathtub Forum & Blog
    Last Post: 08-28-2009, 07:13 AM
  4. HELP! Trying to change Old Price Pfister Avante
    By rjboykin in forum Shower & bathtub Forum & Blog
    Last Post: 07-11-2008, 10:21 AM
  5. Price-Phister Shower Valve / hot=cold; cold=hot
    By EGL in forum Shower & bathtub Forum & Blog
    Last Post: 12-30-2006, 06:46 AM
