Dryer vent
Rayh78
Colonial Heights, Virginia
Right now dryer backs up to an outside wall and the vent is about 10†off floor.
Doing some remodeling and replacing siding. So was thinking of raising the dryer vent to somewhere around 4 ft. off the floor.
But why have I not seen this install height before am I missing something other than looks?
Seems easier to connect hose to dryer push dryer back against wall and THEN connect hose to outside vent.
Seen so many dryers that people connect dryer to vent and then push dryer back to wall and kink hose. Or hose comes loose and they dont even know it.
thanks
First, using a flexible hose on your dryer is costing you money and can pose a fire hazard. It slows the flow down and gives places for lint to accumulate, further closing things. A dryer is always best served with metal, smooth walled ducts without screws holding it together to catch lint on.
A more common exhaust vent location is if the duct runs throught the floor joists above the dryer. Now, depending on which way they run, that may or may not be possible or desirable on a retrofit.
dryer
The hose would look tacky, the extra length would be detrimental, and you would still have to keep the dryer away from the wall so it could make the bend. Buy a "periscope" duct and connect it between the dryer and wall before you slide the washer into place.
Scuba_Dave
Extreme DIY Homeowner
South of Boston, MA
holidaves.com
My last house the dryer was off the kitchen
The event was above the dryer on the right - outside wall
This house the dryer is in th ebasement & vent was thru a basement window
The periscope duct is the way to go
One advantage if the vent is lower & almost stright thru:
Lint can't collect as well
Raising the vent up means lint will fall back down & collect at the bottom creating - as stated - a fire hazard
Ian Gills
Senior Robin Hood Guy
USA
I am buying a dryer vent window when I replace my windows. I'll look into a periscope vent then. I think they sell them up to 50".
