Results 1 to 5 of 5
Thread: Organic trap?
    Default Organic trap?
    I know this is a tough question. I am setting up a hydrogen peroxide injection system for my private well system along with a carbon whole house filter. The water treatment guy that wanted a bunch of money to do this said he recomended an "organic trap" which is basically a water softener with the proper media inside (resin) that gets recharged or backwashed with a brine (salt) solution. He did not tell me what media he would use ,said it was propriatary but he called it an organic trap. I know there is sulpher in the water which is what the peroxide is good at fixing and I know there is some iron but not much and I think that at times during the year there might be tannins present in the water. I have not had much luck at getting a affordable water test to figure this all out and I am wondering about the organic trap media? anyone know anything about this from what I have posted?
    Aug 2008
    Fairfield Co.,Connecticut
    Quote Originally Posted by hotrodjohn View Post
    You need a professional water test!! Imagine calling the doctor over the phone and asking for a prescription without a visit. You are wasting your time and money otherwise without the data.
    Default ok
    I agree, anwhere you can recomend?
    Any water treatment dealer or lab or your county extension office can do the tests; or you can buy a kit and do them yourself. You do not need a certified lab.
    He probably meant a sodium form anion resin used for tannin removal but, if your have iron and H2S you need a correctly sized retention tank and turbidity filter before this "organic" piece or a softener.
    He may be mixing a couple resins in it and doesn't want to tell you what it was because then you'd want to know which ones. And tannin removal can be difficult and he may have found something that works well in your area but IIRC usually tannins don't come and go. Turbidity can.
    Get your test results and post them.
    Aug 2008
    I highly recommend you use a certified lab ... remember you are needing to spend a lot of money for this equipment so trying to save $50-100 would not be wise
