Results 1 to 5 of 5
Thread: Bradford white lowboy
    DIY Junior Member Cybermonkey's Avatar
    Mar 2008
    Vermont
    Default Bradford white lowboy
    Hey guys,
    I am in the process of getting ready to install a hot water heater. My idea is to install the HWH in a closet underneth a stairwell. The problem is my max height is 48". So, I am considering a Bradford White Lowboy 47 gal version. I have a wife, two kids and two bathrooms. I think I will get just enough hot water but am not quite sure. What do you guys opinion????
    BTW, I have no Whirlpool tube or dishwasher.
    Dec 2007
    Go to this link plug in the details and see what it says...
    http://www.bradfordwhite.com/rightspec.asp
    Feb 2005
    Talking it will work ok
    you are talking about a gas low boy, correct???
    that will be more than big enough...
    it will work fine as long as it is permitted to install one
    under a stair well in your area..
    and as long as it dont get starved for air.
    I suggest you put it in a pan for the day will come
    when it will go bad .
    god created all men,
    Default heater
    It had better be an electric heater if he is putting it under a stairway. And the 47 gallon lowboy is equivalent to a 50 gallon regular so you should have no problem with it.
    Mar 2008
    Vermont
    It will be an eletric HWH. I will definitly take your advice and put a pan under it! Do they make a drain for the floor that acts like a check valve? The HWH will sit on my first floor above my crawlspace. If I had a drain to the crawlspace below I would be golden. Accept I am probobibly not seeing a code issue or two.
    Thanks for your help.
