Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Thread: Toto Soft Close Repair?
  1. #31
    DIY Junior Member gldnbrew's Avatar
    Jan 2013
    NY
    Yes they can be repaired. I just finished mine. Took several tries but here is solution. Read the rest of the thread first to see how the closer is taken apart. I tried several thick Silicone greases but here is the one that DOES WORK ACE Brand #4095667 Silicone Grease 90% Pure. Warning this stuff is very sticky and gooey. After cleaning old grease out (not necessary if this is your first time), put a SMALL amount on top of each cylinder and go do something for 10 -15 minutes (it wakes awhile to flow down), when it is all settled down add some more, do this until it is almost up to the top of the cylinders. When this is complete reassemble everything and WALLA a seat that works as good as new.
  2. #32
    DIY Junior Member theob88's Avatar
    Apr 2013
    BC, Canada
    Thanks for the tip gldnbrew. I purchased two of these seats and one of them failed about about 2 years later. I tried repacking the bad cartridge with vaseline and an automotive grease I have and neither worked. I'm glad you found something that does. I don't know where to buy ACE brand products where I live, but looked it up and it's advertised as an o-ring grease. I found this grease http://www.homedepot.ca/product/sili...bricant/910532 on the Home Depot site. It's by Moen and is for valve components but looks to be a similar product. I'll purchase some and see if it does the trick and I'll follow your advice for repacking the cartridge. I'm assuming you reused your o-rings as ones that small are going to be hard to find.
  1. Toto Drake soft close
    By HoneySuckle in forum Toilet Forum discussions
    Last Post: 02-06-2008, 10:38 AM
  2. Toto soft close seat
    By chaoster in forum Toilet Forum discussions
    Last Post: 10-05-2006, 11:18 AM
  3. TOTO ZOE Soft close toilet seat
    By jw1 in forum Toilet Forum discussions
    Last Post: 05-27-2006, 06:07 PM
  4. toto soft close, other options?
    By raygunclan in forum Toilet Forum discussions
    Last Post: 03-23-2005, 08:32 AM
  5. toto soft close, other options?
    Last Post: 03-13-2005, 07:17 PM
