Results 1 to 6 of 6
Thread: Shower head height
    DIY Member richrc1131's Avatar
    Apr 2008
    Central Connecticut
    Default Shower head height
    How high should a shower head be placed above the tub rim?
    I'm asking this because I am remodeling a bathroom that was originally worked on by a guy with a serious drinking problem and I'm new to this stuff.
    Dec 2007
    The height can vary...
    based on preference of the users...
    I assure you that Michael Jordan's showerhead is much higher than mine.
    Default height
    A "littel person" would have his lower than Yao Ming would. Normally we install them 75" above the shower floor.
    Apr 2008
    Central Connecticut
    Default Sounds good.
    Thanks. I needed a standard height because we will be selling this house and I don't want the shower head height to be too "off". A height of 75" sounds good.
    Plumbing Contractor C NUMB's Avatar
    Jan 2009
    NPR, FL
    We mount ours at 6' 8" off rough floor unless the homeowner specifies another height
    I'd Rather Be FISHIN'
    The hole in the wall verses where the showerhead ends up are two different things! I really don't like to have to bend over to stand under the shower. It will depend on the arm and the length of the showerhead where it ends up, and personally, I like it as high as I can get it while still being able to reach to adjust, if desired.
