Results 1 to 4 of 4
Thread: supply lines?
    Default supply lines?
    Am installing tub and shower in old house. Ran copper to 2d floor, terminated with shutoffs. Can I use flexible compression tubes for water supply from shutoffs to faucet? Not the plastic but the reinforced kind, like a toilet feed.
    thanks in advance.
    Plumber jimbo's Avatar
    To the lavatory faucet...yes. Tub no. No kind of compression fitting or flex line can be used in an inaccessible location inside the wall.
    Thanks for the "headsup". Even though the shutoffs will be accessible from the back of the wall, The connection to the faucets won't be. Soooooo I will go with threaded connections. Appreciate your advice.
    Default supplies
    In addition to not being suitable for that location, they have very small internal dimensions so your faucet's flow would be unacceptable.
