Basement finish
chukakid
colorado
Hi, I'm helping my daughter finish her basement and have a couple of questions on the electric plan.
1. I've been told we need to use ARC fault circuit breakers, so wondered if required for all rooms or just the living areas?
2. Next to the bathroom will be a small bar area with a bar sink, so can I use the GFI circuit in the bath for also the counter area or the wet bar? I don't think I can but wanted to check. thanks
Speedy Petey
Licensed Electrical Contractor
NY State, USA
1) Depends on what code cycle you are under and what amendments there are.
You certainly can use them for whatever circuits you want regardless of the code.
2) NO. You cannot share this circuit. The bath receptacle circuit cannot be shared with any other type of room or area.
chukakid
colorado
Thanks Speedy, so does that mean that I have to have one circuit for the bathroom GFI? Seems a tad wastful. Or could I put the whole bathroom circuit on a 20amp circuit including the GFI by the sink?
JWelectric
Electrical Contractor/Instructor
North Carolina
Yes you can put everything in one bathroom on one 20 amp circuit as long as you use #12 for the entire circuit including the light.
This circuit is not allowed to leave this one bathroom.
