Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Antenna installation
    DIY Junior Member
    Mar 2009
    Cannon Township, MI
    Default Antenna installation
    What are the pro's and con's of installing an antenna on a power pole?
    thx aw
    Jun 2007
    NY State, USA
    Define a "power-pole".
    Answers based on the 2008 & 2011 NEC. If you're on the '14 already I feel sorry for you.
    DIY Junior Member
    Mar 2009
    Cannon Township, MI
    The power coming the the grid leads to a junction for my community, then a single power source (feed wire) connects to a pole in my yard, then drops down to my house (connecting to my main breaker).
    Electrical Contractor jbfan74's Avatar
    Jun 2007
    Newnan, GA
    Quote Originally Posted by acwilli View Post
    thx aw
    Dangerous and may be illegal!
    Yes I am A Pirate-Jimmy Buffett
    DIY Junior Member
    Mar 2009
    Cannon Township, MI
    Not illegal according to my power company, because I own the pole, but I was told that the electriacl interferance may be a problem. If graounded how can it be dangerous?
    First off, you have to get up there. Then, to get the coax down, it will may need to run parallel with the power - the worst way to minimize interference. I'd rather put it on the roof, or erect a new pole.
    Jun 2007
    NY State, USA
    You're right. Give it a try.
    What could go wrong.
    DIY Junior Member
    Mar 2009
    Cannon Township, MI
    I do not follow your concept of vertical installation so I attached a picture of my pole. The upper line is electrical and the lower is my cable line. The cable line runs down the pole and is buried the rest of the way to the house. I want to attach my antenna to the top of the pole and tap into the existing cable system feeding my home, but again, I am mostly concerned with the interferance that electricity produces. I do however still would like to know if the antenna is grounded, is there any real lighting danger.
    thx aw
    Jun 2007
    NY State, USA
    ....... and tap into the existing cable system feeding my home,
    To make matters worse, what could you possibly mean by this???
    Jun 2007
    Newnan, GA
    I think he wants to replace the cable feed with the antenna feed.
    DIY Junior Member
    Mar 2009
    Cannon Township, MI
    That's the plan, but safty and plausiblity are the real questions.
    DIY Senior Member thassler's Avatar
    Dec 2006
    Tennessee
    The existing coax cable feeding your house from this pole is probably RG-6. If it's much more than 75ft from the pole to the tv in the house, you're probably going to have to much db loss to get much of a signal.
    Jun 2007
    North Carolina
    810.13 Avoidance of Contacts with Conductors of Other Systems.
    Outdoor antennas and lead-in conductors from an antenna to a building shall not cross over open conductors of electric light or power circuits and shall be kept well away from all such circuits so as to avoid the possibility of accidental contact. Where proximity to open electric light or power service conductors of less than 250 volts between conductors cannot be avoided, the installation shall be such as to provide a clearance of at least 600 mm (2 ft).
    Where practicable, antenna conductors shall be installed so as not to cross under open electric light or power conductors.
    See if you can figure out how you can get connected up and adhere to that section.
    putting it up on that pole is a very bad idea and I recommond that you not put it there
    DIY Junior Member
    Mar 2009
    Cannon Township, MI
    Thanks to all.
    I am definitely not going to attemp.
    aw
    Plumber jimbo's Avatar
    Well, now that they have talked you out of that....I will add that around here ( San Diego) the cell phone companies are using street light poles as antenna location. It is a little different....no overhead power. Just whatever power runs us to the light. Seems to work.
    The use small monopoles. I don't know about your neighborhood, but again, around here, if you tried to put up some kind of TV multidipole anywhere near the public right of way, where others could see it and be offended by the visual blight, the Planning Commission would laugh you out of the room right after the voted 5/1 to disallow your permit!!!
