Results 1 to 2 of 2
Thread: insulation
    DIY Junior Member 7echo's Avatar
    Jan 2008
    coastal georgia
    Default insulation
    I am remodeling a bathroom and will have an acrylic tub. Is it OK to foam(low expansion) the voids in the wall areas of the tub? It will be set on a mortar bed, with poly between the tub and mortar. I am thinking it would be good to insulate the tub wall cavity. I am talking specifically about the area between the inner and outer tub wall, the room walls will be insulated with batts.
    Software Engineer BlackNoir's Avatar
    Mar 2009
    Centerville, MN
    I was just wondering the same thing.
    Was also wondering if there was a way to insulate a whirlpool motor so it's not so loud?
