Results 1 to 11 of 11
Thread: soaking tubs with long leg lengths
Hybrid View
    Default soaking tubs with long leg lengths
    Looking for a soaking tub with a basin bottom length of about 46". All tubs seem to be designed as whirlpools with space taken up for the motor/pump at expense of legroom. Does anyone make just a soaking tub? Need 3 wall alcove style; 60" by 32" by 18" high. Do not want to move a wall for a 66" tub.
    Plumber Cass's Avatar
    Nov 2005
    I think Sterling/Kohler has one that can be ordered from a plumbing supply house...
    I think you'd be better off with a longer tub...I went for a 6' one, and would be in heaven if I could have fitted a 7' one in there. Most of the manufacturers use the same casting for their soaking, air, jetted, or air/jetted tubs, and therefore, yes, restrict the length of the bottom.
    Thanks for replies. The longest Sterling, the Accord, is close at 46" but still not long enough. Are there any tub makers who just make 3-wall soaking tubs rather than soaking/whirlpools combos, which use up lengthwise space for the motor/pump. Have looked at all American Std, Kohler, Maax, Sterling, Jacuzzi models. Thanks
    I teach guitar:You call that a job? Howard Emerson's Avatar
    Apr 2008
    Huntington Station, NY
    Quote Originally Posted by ted burke View Post
    Ted,
    Jason International (The Jacuzzi family business) have a bunch of their tubs available as soaking tubs only, and they are even deeper.
    The problem you are asking for is for more flat leg space. The reason it will be a problem is that they can only give more flat leg space by decreasing the angle of the back support, and making it closer to vertical.
    That will be far more uncomfortable than having to bend your knees a bit.
    All their tubs are available with a tile lip on any number of sides.
    http://www.jasoninternational.com/pr...=60&WidthId=32
    Regards,
    Howard
    http://www.howardemerson.com/
    Almost everyone that makes whirlpool tubs sell them as soakers...think of it as a delete option.
    Thanks for suggesting 60" Jason Tubs. They say they only make combo soak/whirpool tubs and their longest basin length is 42", short of the 46" I'm looking for.
    Apr 2008
    Ted,
    Why is the 46" so important?
    HE
    Why 46" important? I'm 5'-11" with avg legs. My cheapo worn 1 piece 60" builder line bath/shower measures 47" at the basin and I can strengthed my legs out. With NO 60" tub that I know of can I do that.
