Results 1 to 3 of 3
Thread: square drain help
    Default square drain help
    Hi all,
    I'm redoing my shower and would like to put in a square drain. I've found one at lowe's, but the clamping ring has 4 holes, whereas my current one has only 3, and I'd like to avoid ripping out the whole drain. Any ideas where I can find a square drain with a 3 hole clamping ring? I have a lowes, ace, home depot, and fergusons around here, with a few places, but I'm not opposed to online.
    Thanks for your help. Let me know if I'm not using the right terminology. I think my 3 hole clamping ring had a different size so I couldn't just swap parts iwth the new square drain with 4 hole clamping ring.
    Plumber jimbo's Avatar
    Sounds like you are trying to mix-and-match. That never works.
    Default drain
    Even if you found one, there is no guarantee the bolt pattern would be the same. There are NO standards so each company makes its own design.
