Results 1 to 14 of 14
Thread: Brand New Washing Machine Hose Squirts Water Everywhere, What Am I Doing Wrong???????
    Default Brand New Washing Machine Hose Squirts Water Everywhere, What Am I Doing Wrong???????
    Everyone,
    I'm at a complete loss!!! I just relocated my washing machine from the bathroom to the kitchen (I installed a stand-up shower in the bathroom and built a cabinet in the kitchen for the washer/dryer).
    I've bought two Floodsafe Stainless Steel hoses, and a set of rubber hoses (all with the L bracket connection which connects to the washing machine side (total of 3 hose sets). All of them are gushing water from the L-Bracket connection which connects to the washing machine side.
    The water supply side doesn't leak at all, but the washing machine side, with the L bracket literally POURS water out of the center of the connection. The ONLY thing I can think of is that the original hose (which has a plastic connection L bracket), which also connects to a plastic fitting which is permanently fixed to the washing machine is the problem since "ALL" of the hoses I've bought are metal threads on both ends, vice the original which is metal threads on the water side of the hose, and plastic threads on the washing machine side of the hose????
    Is this the problem? Can I not connect a metal threaded hose to a plastic threaded connector? As I mentioned before, this is the 3rd hose that I've installed and none of them work except the original hose that came with the washing machine (metal on one end, plastic on other end). When I reinstall the original hose, no problems at all, when I install a new hose, it pours water from the center of the L bracket metal connection!!!!!!
    If this is the case, where in the HELL can I find a 6 foot hose that is plastic on one end, and metal on the other so I can install my washing machine safely without worrying about flooding the apartment below mine.
    I'm at a loss guys, please help!!!
    Apr 2005
    Awe man!
    You cross-threaded it and broke it!
    Not good! Take pictures!
    The first picture is the original connection. Note that one side if plastic (washing machine side) and the other side is metal (water supply side:
    The second picture is the 3rd set of hoses I bought from Home Depot/Lowe's. All the aftermarket hoses I've bought have been metal threaded both sides:
    The third picture is of the L bracket shaped hose connection. Notice the center of the connection, where the L-bracket connects into the threaded portion. The water is gushing from the center where the two pieces connect (Yes, the washers are installed):
    Quote Originally Posted by RUGGED View Post
    Awe man!
    It's not cross threaded, it's not leaking from the threads. It's leaking from the connector where the L-bracket elbows into the metal threaded circular piece.
    Dec 2007
    Do you have rubber washers inside those connectors?
    Quote Originally Posted by Redwood View Post
    Yes, the washers are inside.
    What brand of machine? I would not allow a hose with a plastic fitting on it in the SAME STATE, and certainly not inside my house. You are asking for a disaster on that.
    I can only think that some off brand or import machine has non-standard threads on the inlet?? And maybe that is why only their hose works??
    Plumber Cass's Avatar
    Nov 2005
    What are you using to tighten them???
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    Although it might be kinda hard, can you connect the 90 degree connection to the hot or cold supply and have the straight connection going to the washer¿ I realize why you are using the right angle hose, to gain extraspace (or are you¿ if not try a regular washer hose) Does it still leak at the 90 with them reversed¿
    Default hoses
    Why aren't you using hoses with metal angle ends on them instead of the plastic ones. If it is leaking ANYWHERE except where it connects to the washing machine the hose is either not tight or it is defective.
    Everyone,
    The original hoses that were installed were made by Whirlpool (machine and hoses came together when I bought the machine). The original hoses that came with it, which have a plastic L-Bracket (90 degree bracket) don't leak at ALL.
    The aftermarker hoses, all which are metal and have a L-Bracket (90 degree bracket) leak at the where the 90 degree bend is on the hose side that attaches to the washing machine.
    Problem...............factory plastic one's don't leak, aftermarket metal ones do.
    Nov 2008
    Chicago, IL
    Sometimes the trouble is the socket on the new hoses are to deep so no matter how tight you tighten them you will not compress the washer. You can try doubling up a washer in the metal ends or find a thicker hose washer.
    Quote Originally Posted by SewerRatz View Post
    That's what I think the problem is personally, but I don't feel safe with doubling up washers as the resolve to the situation when I live in a condo and people live beneath me. Any other thoughts?
    See if you can find some that are thicker. Also, you could measure the depth of the OEM ones verses the new ones. It should be obvious if when screwing them on if you are bottoming out on the shell or compressing the washer.
