Results 1 to 8 of 8
Thread: Surging Pump
    Default Surging Pump
    Hello I have a Davey Hp Torrium pressure pump that has started surging everytime the water is turned on. Any ideas on what might be causing this?
    Thanks in advance
    Previous member
    Jul 2005
    Riverview, Fl.
    It's broke.
    A regular jet pump on a flow switch would be better than the Davey.
    bob...
    Moderator valveman's Avatar
    Mar 2006
    It is the flow switch thing in the Davey pump that is causing the problem. It is doing exactly what it is supposed to do. That is work for a short while,(just past the warranty time) then quit working, so you have to buy another one. A jet pump with a pressure switch, small tank, and CSV will give you years of trouble free service.
    Thanks for the replies but the pump is only a couple of months old!, would it have anything to do with the torrium on top?
    Does this happen alot with these types of pumps?
    Previous member
    Jul 2005
    Riverview, Fl.
    These pumps are very cheaply made and so are their other components. They weren't meant to last a long time.
    If it's less than a year old, why don't you send it back for warranty.
    bob...
    Mar 2006
    See if they will let you change it out for a pump with a standard pressure switch and pressure tank, because it is the torrium thing on top that always causes the problem.
    Previous member
    Jul 2005
    Riverview, Fl.
    Ah, so they're called Torriums this week.
    bob...
    Previous member sammyhydro11's Avatar
    Dec 2006
    Massachusetts
    Fancypants,
    are you from Westport MA?
    sammy
    www.tylerwellandpump.com
