Results 1 to 8 of 8
Thread: Toto CST703.10 Reviews?
    Default Toto CST703.10 Reviews?
    I've done some searching on the forum but I've only seen mentions of the TOTO CST703.10 (10" rough), mainly that it splashes when flushed. It seems like this model is the best fit for my installation, which sadly has a 3" forced hot water baseboard to contend with along with an 11.5" rough from the wall (not including the baseboard).
    So I'm wondering if anyone out there can comment on their satisfaction level with the Toto CST703.10 or point me to an review of it. I'd also appreciate any suggestions of other models or manufacturers I should consider given the installation constraints. (Photo of existing American Standard toilet & drawing of the Toto provided below).
    I've read that I should consider installing a waxless seal given the baseboard heater, but my old American Standard has had no problems other than using way too much water.
    Thanks everyone!
    You may also want to look into the Toto Dalton.
    No splash, the flush is good, and it has room behind the bowl.
    Default Thanks!
    Thanks Terry - this looks like a good option.
    In the Trades MaintenanceMan's Avatar
    Dec 2008
    Indiana
    I installed two of the CST703.10's in a building where I work last week. They seem to work fine, but as I said it's only been a week. They only get "punished' about one day a week. I only had 10 3/4" so they worked out great for me as far as install goes.
    DIY Senior Member SamC's Avatar
    Apr 2007
    Georgia
    MaP testing indicates the 703 flushes 550 grams, while the Dalton flushes 650 grams. I believe the Dalton has a jet while the 703 does not.
    DIY Junior Member Nick Gibb's Avatar
    Mar 2012
    Chicagoland, IL
    Default What can you tell me about the TOTO Reliance???
    I have the possibility of being able to purchase a Toto Reliance toilet with a 10" rough in at a STEAL of a price. I believe it is a discontinued model, so I wanted to get some input, review, thoughts as to whether it is a good toilet or if there is a reason (other than aesthetics) that it is no longer produced by Toto.
    It must be a discontinued model because Terry has not had it listed on this site in the several years I have been lurking about. I know they discontinued the Carouso model because it did not perform exceptionally well and other models that did perform sold for just slight more. Can't say for sure if the Reliance fits that description or not, but if I had to guess, I guess that would be the reason.
    Just a follow up on the above post. The Dalton has been discontinued. While it wasn't a "bad" toilet, the Drake was better for almost the same price. Again, I think that was likely the fate of the Reliance. Not having first hand knowledge doesn't help much, but since you got this Reliance for " a steal", try it. If it works for you, you're the smartest shopper in town. If it doesn't, you're not out a fortune. Such is the way of buying bargains. Sometimes you win and sometimes you don't.
  1. Toto Promenade? Any reviews?
    By misskerri in forum Toilet Forum discussions
    Last Post: 02-22-2012, 05:07 PM
  2. Toto CST703 - erratic flushing - need help, please
    By Tinger in forum Toilet Forum discussions
    Last Post: 11-23-2011, 01:27 PM
  3. Toto Carlyle II vs. Vespin II reviews?
    By HarryPotter in forum Toilet Forum discussions
    Last Post: 04-29-2011, 10:03 AM
  4. Toto CST703 Toilet Not Clearing
    By kit in forum Toilet Forum discussions
    Last Post: 01-12-2010, 10:20 AM
  5. Toto CST703 Flapper Valve Leak
    By Houdini in forum Toilet Forum discussions
    Last Post: 01-12-2009, 09:34 AM
