Results 1 to 7 of 7
Thread: Why does light bulb blow?
    DIY Member Blumengarten's Avatar
    Nov 2008
    Pennsylvania
    Default Why does light bulb blow?
    Why would a bulbs in a light fixture suddenly start blowing when you turn it on? I suppose that means there's a short in the system, but why would one develop suddenly? We've been using this light fixture for many, many years, and never had problems with the bulbs blowing out, but in the last month, we've had to change the bulb three times. How could a short develop when you've not done anything but turn a light on and off?
    DIY Senior Member TedL's Avatar
    Sep 2006
    NY Capital District
    What kind of a fixture is it?
    Has anyone touched any wiring in the house?
    Nov 2008
    Pennsylvania
    Quote Originally Posted by TedL View Post
    It's a single bulb in a hanging light fixture with one socket. It's plugged into a wall outlet. The fixture was re-wired about three years ago, but the bulb's just started blowing out these past few weeks.
    are your bulbs old ?
    Sep 2006
    NY Capital District
    Do you have a V-O-A meter? If not, get one and check the voltage between the center "button" and the outer shell.
    Even a $2 sale meter from Harbor Freight will be good enough for what you need. Elsewher, you'll pay $10 - 15.
    Plumber jimbo's Avatar
    "shorts" not likely to blow bulbs. This could be a symptom of an open neutral problem. I would have a good electrician give your house the once over,.
    Nov 2008
    Pennsylvania
    Quote Originally Posted by Cookie View Post
    No, I've been using new bulbs each time!
    Even a $2 sale meter from Harbor Freight will be good enough for what you need. Elsewhere, you'll pay $10 - 15.
    $2 I can afford!
    I was thinking of doing that eventually since I plan on renting this house out come summer -- it's my deceased mother's house which I inherited, I want to make sure everything's safe before I rent it out!
