Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Why won't garbage disposal reset?
    DIY Member Blumengarten's Avatar
    Nov 2008
    Pennsylvania
    Default Why won't garbage disposal reset?
    The garbage disposal got over-filled and stopped. I cleared everything out of it, pressed the reset button, and turned it on. I could hear the engine whirring, but not engaging. I checked to make sure there was nothing left inside, I couldn't feel anything, I unplugged it, pressed the reset button, turned it on, and same result. Do you know what's the matter?
    Joy
    Nov 2008
    Chicago, IL
    It is jammed. Turn it off and use the tool that comes with the disposail and insert it in the socket in the bottem of the unit and give it a few good turns. Remove the tool, then try running it again. The tool looks like this.
    Nov 2008
    Pennsylvania
    Okay, thanks! I wondered what that was for.
    Nov 2008
    Chicago, IL
    Quote Originally Posted by Blumengarten View Post
    Let us know if it worked.
    Default disposer
    There is no "engaging". If the motor runs so does the grinding plate. You are hearing the motor "trying" to run and if you leave it on too long the reset button will pop out again. Unjam the disposer and remove whatever is causing the jam before trying to run it again.
    Nov 2008
    Pennsylvania
    Quote Originally Posted by SewerRatz View Post
    Yes thank you! I didn't know what that little wrench was for. Thanks for your help!
    Nov 2008
    Chicago, IL
    Awesome, always glad to be of a help. Most people have no idea what that wrench is for. It also serves another purpose for installing and removing the disposal from its flange. I have had home owners call me to tell me I forgot a tool behind.
    Dec 2007
    Whenever I install a disposer it includes a lesson of how to unjam a disposer.
    If I'm sent a call to unjam a disposer the same lesson is also included.
    Aug 2008
    I was taught to tighten the last space left with a pair of channel lock pliers. Squeeze the two together and drive away.
    Nov 2008
    Pennsylvania
    That's a good policy! Your customers surely appreciate it! (I'd feel silly calling a plumber to unjam a disposer, I'm so glad I found this website!)
    Aug 2008
    I've had some that were a real bear to unjam. One had a brad nail in it. That sucker took some ingenuity to finally get out.
    Dec 2007
    Quote Originally Posted by kingsotall View Post
    I've seen that a couple of times...
    Dec 2007
    I consider it to be an important part of taking care of the customer.
    Maybe a good reason to use my services again when really needed.
    I've unjammed mine with the end of a broom.
    Aug 2008
    I need to work on this more often. Sometimes when a job goes fast there can be time to educate the customer. Just gets hard when you're late for the next customer.
