Results 1 to 7 of 7
Thread: PVC Wall Tube Connection
    DIY Junior Member BillM's Avatar
    May 2007
    Michigan
    Default PVC Wall Tube Connection
    Hello all.....
    Please bear with me, but I've got a very basic question......
    I have 1-1/2 inch PCV Wall Tube from behind vanity. I am trying to connect Plastic P-Trap to the PVC. The PVC has no threads......just straight PVC coming out of wall.
    What is best way to attach connector? 1-1/2 inch connector doesn't seem to fit correctly? Is the term "Desanki" familiar? Local plumbing supplier told me that I "cut off the Desanki", when I shortened the wall pipe......so now attempting to reconnect, but standard HD plastic doesn't seem to be a 'tight' fit? Don't want a leak problem later?
    What am I doing wrong?
    Thanks for info...
    -Bill
    Yakima WA
    I'm just a DIYer, so admittedly there are lots of things I don't know, but I have no idea what a "Desanki" is, Google doesn't either. But, to transition from PVC pipe to a P trap, you need a threaded adapter. Smock man at HD didn't give you very good advice. You would be wise to have someone illustrate how to make this connection with actually pieces of pipe and fittings.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    It is called a desanko or trap adapter.The term desanko comes from the man that invented it.It was his name.
    May 2007
    Michigan
    Thank you......I'm just back from HD......
    Gary....you were right.....Smock Man did steer me wrong.....
    cwhyu2......thanks for clarifying 'Desanko'.......
    Bottom line - Desanko=Trap Adapter.....and that's what I ended up with......finally......
    Thanks again!
    Default connector
    DeSanko, Marvel connector, waste and vent connector, trap adapter, and maybe others, all of them refer to the same thing. I am not sure that De Sanko invented it because we used them for decades before I heard his name associated with it. Which one you use depends on which part of the U.S.A. you are in.
    Yakima WA
    Well, another day and I've learned more stuff!
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    tomato tamato
