Hi i have installed a pressure reducing valve on the main inline .there is a backflow valve at meter.there is also a expansion tank on cold at water heater..is 55 on prv and 45 -tank about where it should be?...its a 2 gal exp tank and heater is 50 gal.
I later found that a single T in main line to cold washer -stand alone(no where else)has been installed in a difficult to get to area.I am getting 85 psi sometimes 120 from the line pressure-in -this valve only.
Can I place a pressure relief valve (BPV-watts)between the outlet and hose connection and have empty to drain right there 3 inches away? and what psi if it is an option(they make an ajustable one)?
Would a washer arrestor give it a bit of relief during the on/off shut offs or work as a cushion to the spikes?
Any info or new ideas are appreciated
