Here in Illinois you are allowed to use PVC for water pipe as long as it meets the appropriate NSF standard for potable water and for cold or tempred water. Below is taken from the Illinois code book, text in red is done by me. A note to remember even though Illinois allows certain material, the counties and cities may disallow it.
Approved Materials for Water Service Pipe
1) Acrylonitrite Butadiene Styrene (ABS) Pipe2 ASTM D 1527-1996a, ASTM D 2282-1996a
Joints ASTM D 2235-1996a
Solvent Cement1 ASTM D 2235-1996a
2) Brass Pipe2 ASTM B 43-1998
3) Cast Iron (ductile iron)2 ASTM A 377-1984
Water Pipe CSA B70-1997
4) Chlorinated Polyvinyl Chloride (CPVC) Pipe2 ASTM D 2846-1997M, ASTM F 441-1997, ASTM F 442-1997, CSA B137.6-1999 in B137
Joints ASTM D 2846-1997M, CSA B137.6-1999 in B137
Solvent Cement (Orange)1 ASTM F 493-1997, CSA B137.6-1999 in B137
5) Copper/Copper Alloy Pipe 2,3 ASTM B 42-1996, ASTM B 302-1998
6) Copper/Copper Alloy Tubing 2,3 ASTM B 88-1996
7) Galvanized Steel Pipe2 ASTM A 53-1998, ASTM A 120-1984
8) Poly Butylene (PB) Pipe/Tubing2 ASTM D 2662-1996a, ASTM D 2666-1996a, ASTM D 3309-1997a, CSA B137.7-1999 in B137, CSA B137.8-1999 in B137
9) Polyethylene (PE) Pipe2 ASTM D 2239-1996a
10) Polyethylene (PE) Tubing2 ASTM D 2737-1996a, CSA B137.1-1999 in B137
11) Polyvinyl Chloride (PVC) Pipe2 ASTM D 1785-1996b, ASTM D 2241-1996b, ASTM D 2672-1996a, CSA B137.3-1999 in B137
Joints ASTM D 2855-1996, CSA B137.2-1999 in B137, CSA B137.3-1999 in B137
Primer ASTM F 656-1996a
Solvent Cement1 ASTM D 2564-1996a, CSA B137.3-1999 in B137
12) Welded Copper Water Tube2 ASTM B 447 WK, WL, and WM-1997
13) Solder ASTM B 32-1996
Agency Note:
1 Solvent cement must be handled in accordance with ASTM F 402-1988.
2 Water service pipe must meet the appropriate NSF standard for potable water.
3 Type K or L copper may be installed underground.
Approved Materials for Water Distribution Pipe
1) Brass Pipe2 ASTM B 43-1998
2) Chlorinated Polyvinyl Chloride2 (CPVC) Pipe/Tubing ASTM D 2846-1997, ASTM F 441-19973, ASTM F 442-19973, CSA B137.6-1999 in B137
3) Copper/Copper Alloy Pipe2 ASTM B 42-1996, ASTM B 302-1998
4) Copper/Copper Alloy Tubing2 ASTM B 88-1996
5) Cross Linked Polyethylene2 ASTM F 876-2000, ASTM F 877-2000, CSA B137.5-1999 in B137
6) Galvanized Steel Pipe2 ASTM A 53-1998, ASTM A 120-1984
7) Poly Butylene (PB) Pipe/Tubing2 ASTM D 3309-1997a, CSA B137.7-1999 in B137, CSA B137.8-1999 in B137
8) Polyvinyl Chloride (PVC) Pipe 2,3 ASTM D 1785-1996b, ASTM D 2241-1996b, ASTM D 2672-1996a, CSA B137.3-1999 in B137
9) Welded Copper Water Tube2 ASTM B 447 WK, WL, and WM-1997
10) Solder ASTM B 32-1996
Agency Notes:
2 Water distribution pipe must meet the appropriate NSF standard for potable water.
3 Use for cold or tempered water only.
