Results 1 to 6 of 6
Thread: bubbles in water
    Default bubbles in water
    have water softener salt level fine regeneration fine recently turned off water upstairs to remodel bathroom lately water from tap looks cloudy turns out it's bubbles they all rise to top of glass and water then looks clear never had this problem before have a well pressure is fine anybody have any ideas what could be the cause of extreme aeration thank you
    Default bubbles
    thanks, will check softener because bubbles have been going on for about 2 wks
    you can check to see if it is the aerator adding the water by removing the aerator and drawing water into a glass and if it doesn't have the air then it is the aerator causing the air like they are supposed to it could be lose brine line connections on the softener or the air check valve isn't sealing because it has something blocking it from sealing or it could be the valve you shut off sucking air around the stem packing
    gary, thank you it was the valve i shut off sucking air
    You're welcome Mike, thanks for the feedback.
    Sammy, if you read this, maybe your air in the water is a valve stem leak on a shutoff valve.
    Previous member sammyhydro11's Avatar
    Dec 2006
    Massachusetts
    Gary, i know where my customers well problems come from but thanks for the suggestion.
    sammy
    www.tylerwellandpump.com
