Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: supply and drain tied together??
    DIY Member brother's Avatar
    Dec 2007
    Washington
    Default supply and drain tied together??
    I was looking at a rinser that only had one way to to fill it up and one way to drain. it used the same pipe. Now mind you there was (I believe a backup valve?) 2 solonoids that when one is open that let the water in the one going to the drain is closed, and when the drain is open the supply is closed.
    The only problem I have is that for a short section about 2ft to 3ft the drain water can be mixed with the supply water, (thats just the residual). I admit im not a plumber, but would this set up be legal?? Even if it was I would not want anything I got with this set up. Any guidance would be appreciated.
    Dec 2007
    How about a picture of what you are talking about...
    Plumber Gelo30's Avatar
    Feb 2009
    Hawaii
    Hard to figure out. what you elaborate and show some diagram of that.
    Default rinser
    ANY device that had both drain and potable water where they could mix, regardless of how the solenoid valves were cycled, WILL BE ILLEGAL, unless it had very stringent protective devices.
    Yakima WA
    Just the thought of supply and drain connected anyway should be a red flag to you. I think if anyone on this forum knew of such a thing, it would be HJ and he obviously doesn't. So, whatever you are trying to do needs at least a Plan B.
    Dec 2007
    Washington
    I wish I could put a picture up, dont really know how. this is something Ive found, even though they have a 'electric' solenoid and another valve that suppose to keep the 2 from mixing. But like I said there is just the last little bit of plastic tube (pipe), that a little residual of the drain is left. What is a code I can find to quote to these guys.
    Dec 2007
    Washington
    This is NOT something im doing, so no 'plan b' is needed for me. This is just something I ran into and it was installed by a plumber.
    Nov 2008
    Chicago, IL
    If you could find a name on this it might help.
    Default thing
    This may be a duplicate or it may not have been posted the first time. There is no legal device which would connect water and sewer together, without some physical gap/barrier, regardless of any valve sequence to keep them separated. And NO amount of drain water in the water line is acceptable, even if it were just some infinitessimal drops.
    Dec 2007
    Washington
    Quote Originally Posted by SewerRatz View Post
    I will see what I can do.
    Dec 2007
    What is this used on?
    I'd like to have some clue of what you are talking about.
    Default thing
    That has been the problem from day one, because I cannot visualize any use for this thing, how it was made, or who made it, or more important WHY it was made.
    DIY Senior Member SteveW's Avatar
    Feb 2005
    Omaha, NE
    Are we talking about a kitchen fixture?
    I saw an in-counter pasta boiling arrangement at a high-end kitchen store once, which appeared to have a solenoid-controlled drain at the bottom. (to fill it you used a swinging pot filler faucet from above.)
    Nov 2008
    Chicago, IL
    Quote Originally Posted by SteveW View Post
    I have seen this too, it was a Kohler pasta boiler that was built into a sink that is connected to the drain with a solenoid controlled drain. I could never wrap my mind around how that was allowed having a boiler tied into the sanitary waste system. http://www.designtool.kohler.com/us/...sp?item=241302
    Feb 2005
    Omaha, NE
    That's the one!
    I see it is discontinued.
