Results 1 to 15 of 18
Thread: supply and drain tied together??
Hybrid View
    DIY Member brother's Avatar
    Dec 2007
    Washington
    Default supply and drain tied together??
    I was looking at a rinser that only had one way to to fill it up and one way to drain. it used the same pipe. Now mind you there was (I believe a backup valve?) 2 solonoids that when one is open that let the water in the one going to the drain is closed, and when the drain is open the supply is closed.
    The only problem I have is that for a short section about 2ft to 3ft the drain water can be mixed with the supply water, (thats just the residual). I admit im not a plumber, but would this set up be legal?? Even if it was I would not want anything I got with this set up. Any guidance would be appreciated.
    Dec 2007
    How about a picture of what you are talking about...
    Plumber Gelo30's Avatar
    Feb 2009
    Hawaii
    Hard to figure out. what you elaborate and show some diagram of that.
    Default rinser
    ANY device that had both drain and potable water where they could mix, regardless of how the solenoid valves were cycled, WILL BE ILLEGAL, unless it had very stringent protective devices.
    Yakima WA
    Just the thought of supply and drain connected anyway should be a red flag to you. I think if anyone on this forum knew of such a thing, it would be HJ and he obviously doesn't. So, whatever you are trying to do needs at least a Plan B.
    Dec 2007
    Washington
    I wish I could put a picture up, dont really know how. this is something Ive found, even though they have a 'electric' solenoid and another valve that suppose to keep the 2 from mixing. But like I said there is just the last little bit of plastic tube (pipe), that a little residual of the drain is left. What is a code I can find to quote to these guys.
    Dec 2007
    Washington
    This is NOT something im doing, so no 'plan b' is needed for me. This is just something I ran into and it was installed by a plumber.
    Nov 2008
    Chicago, IL
    Default From Illinois Code book
    Section 890.1130 Protection of Potable Water
    e)Prohibited Connections.
    1) Sewage Lines. There shall be no direct connection between potable water lines and lines, equipment and vessels containing sewage. Such connections shall be made only through a minimum fixed air gap.
    Default tool
    There is no way you can safely or legally include the words, "water", "drain", and "DOCTOR"S tool" in the same sentence without a MAJOR caveat as to how it must be done.
