Results 1 to 15 of 15
Thread: Need to find a wrench for this
    DIY Senior Member Melissa2007B's Avatar
    Jun 2007
    Denver, CO
    Default Need to find a wrench for this
    We have this main line cleanout cap in the driveway and it's an inverted square. Dont they make a wrench that will open this?
    Melissa
    Denver Process Servers
    http://DenverProcessServers.net/
    Nov 2008
    Chicago, IL
    We use two large screw drivers , stick each one in opposite corners crossing the blades and twist. There is a manufacture that makes square head tools for the counter sunk plug as well.
    Jun 2007
    Denver, CO
    Quote Originally Posted by SewerRatz View Post
    Thanks. Any idea what they call that tool?
    Melissa
    Nov 2008
    Chicago, IL
    They call that tool a Eureka Cleanout Plug Wrench Lets see if this link works http://www.azpartsmaster.com/Product...__PAS4567.aspx
    Jun 2007
    Denver, CO
    Thank you!
    Melissa
    Feb 2005
    Talking hammer and small cold chisel
    I always thought you were supposed to use a hammer and small chisel to open those up, slightly tapping in the right direction along the outer threads usually works ...
    but that is a neat tool....
    Nov 2008
    Chicago, IL
    Quote Originally Posted by master plumber mark View Post
    You know me, I must have new tools. I have a few I made for certain applications. One day I will take some pictures of them and post them up.
    Dec 2007
    Being in the trade I have that tool as well.
    Problem is every time I find one of those some Idiot new construction plumber has always set the cleanout so deep in the floor that the tool won't reach it...
    If I was on Mellisa's situation where it's a one time use I would just measure the size of the square and buy a pipe plug with the same size square and turn it with a pipe wrench.
    Save a bit o cash...
    Last edited by Redwood; 03-06-2009 at 07:02 AM. Reason: cause the letters i pressed on the keyboard don't show up on the monitor
    Nov 2008
    Chicago, IL
    Quote Originally Posted by Redwood View Post
    Problem is every time I find one of those some Idiot new construction plumber has always set the clean out so deep in the floor that the tool won't reach it...
    The tool is only 12 bucks. I have a tool like that but the squares are extended a foot for the clean outs that are below the floor. I will take a picture once I pick up a new digital camera.
    Master plumber Jay Mpls's Avatar
    Sep 2008
    Minneapolis
    I use a pipe wrench,channel locks or hammer and cold chisel and have a supply of 4" pvc flush plugs and 'real tite' plugs ready to go.
    Jun 2007
    Denver, CO
    You cant have TOO MANY tools.
    Melissa
    Default tool
    A section of the proper size square tubing from HD or Ace hardware will work also. That's assuming ANYTHING will turn it. In most cases it will have to be cut out and replaced.
    Jun 2007
    Denver, CO
    No, we keep it loose so it can be turned. We've had so many problems with the plumbing here....
    Melissa
    Default loose
    Loose is good, but even if it were not, it would not be a "plumbing problem" it would just be the normal situation. As my dad always said, "they make those plugs thin so we can chop them out easier."
    Jun 2007
    Denver, CO
    I was gonna look down there and see if I could tell anything, but I'm REALLY glad that I got the right plumber over here instead. This was a terrible mess that none of the rooter people could have ever solved:
    http://www.terrylove.com/forums/showthread.php?t=27371
    Melissa
