Results 1 to 7 of 7
Thread: remove a shark bite
    DIY Junior Member JoeT's Avatar
    Oct 2007
    Scranton Pa.
    Default remove a shark bite
    Hi folks, is there a way to remove a shark bite coupler from a copper pipe?
    Joe T
    Oct 2007
    Scranton Pa.
    never mind....I found the answer.....helps to search first....thanks folks
    Joe T
    Default Sb
    Not sure which advice you found, but if you do not have the regular removal tool, a Crescent wrench adjusted to the tubing size pushing against the removal collar will take it off.
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    This tool will also work
    That weren't funny... forgive me lord
    Default funny?
    That weren't funny... forgive me lord[/quote]
    Actually you are partly correct. It would not be the first time I have used a smaller version of that "TOOL" applied to the side of the Crescent wrench to persuade a tight SB fitting to surrender.
    Jul 2008
    S. Maine
    spent the day at a PHCC sponsored trade shows. Sharkbites and pex as far as the eye can see.
    DIY Senior Member seaofnames's Avatar
    Jan 2009
    Mission, BC
    Quote Originally Posted by nhmaster View Post
    I'm guessing its the way of the future!
    I'd never use a SB for a permanent installation.
    Copper should always be used in some degree, but DIYs look for quicker/easier ways to install pipe, not necessarily better ways.
