Sounds like a sump pump would work for you but I wonder about the affects of the added quantity of discharge and brine solution on your septic system?
A good sump pumps installation should be discharged to a drainage pipe which carries the water away from the home on the downhill side. This will prevent the water from coming back towards the foundation without affecting the septic system. This could drain to daylight or to a dry well on the property.
