Results 1 to 4 of 4
Thread: Dual zone vs. Single zone?
    Default Dual zone vs. Single zone?
    I'm shopping for a mini-split heat pump and noticed that the dual zone units are alot more expensive than the single zone units. What is the difference in the two? Thanks.
    Some actually use a separate compressor for each zone. Some use a separate evaporator for each zone. Duplicating the expensive bits adds to the cost.
    Quote Originally Posted by zombieman View Post
    Well, for starters, you have an extra indoor unit. Also, you will have a bigger compressor. LG is now using some very fancy technology, a "variable" compressor.
    I am guessing a dual zone unit costs less than 2 single zone units>???
    Like an engineer alternety's Avatar
    Apr 2006
    Washington
    A factor in considering this is will the single zone coil provide even heat in the required area. In point of fact, will a dual zone accomplish this.
    It is effectively a window installed heater. Can you heat or cool what needs to be conditioned from such a unit without other air circulation. If no, and you do not have such an air circulation system, you have a problem. Since heat pumps tend to have low "warm air" temperatures to start with, this could be problematic.
