Results 1 to 6 of 6
Thread: Ideas for 2-handle tub diverter preserving tile?
    DIY Junior Member Chessiec's Avatar
    Jan 2009
    durham, nc
    Default Ideas for 2-handle tub diverter preserving tile?
    Plumber has said my 1948 home's tub/shower faucet and tub diverter spout are shot. We have great vintage tile that we don't want to replace, and the cover-up with ears to cover holes from our 8" spread faucet (at least what I've seen at the big box) and go to a single handle set up looks rather terrible to me.
    Anyone have a more elegant way to cover the holes in order to go to single lever? The bathroom double sinks each have a delta single lever on them.
    I'm assuming the easiest and best thing to do is go back with a new 2-handle faucet, tub diverter spout set. The options are limited. Kohler Coralais or Revival, Moen Monticello, Price Pfister Savannah, or Newport Brass 3-803. I can't find Delta, Grohe or Gerber in 2-handle.
    In looks, I probably like the Newport the best, Kohler Revival traditional lever best. But I know some on this board have good reason to not favor these brands, and function is highest priority. Any feed back on these options, or a pointer to others any of you like? And I assume I can use the Delta diverter spout (pull down, metal) with any of these?
    Thanks for any help.
    Instead of using a divertor tub spout, you could use the second hole for a divertor valve.
    Another possibilty is what I have in my home made by Grohe.
    I'm pretty sure it adjusts to 8" - the piece that screws into the el in the wall has an offset to it, so you can adjust the spread.
    Jan 2009
    durham, nc
    Default Looks great! But what is it?
    Jim,
    Grohe stuff always looks great to me. But....um...I'm not sure I know what that is and how it works.
    Jan 2009
    durham, nc
    HERE IT IS: But discontinued...And I don't think it will do for us.
    Exposed Thermostatic Shower Valve, 34 067
    Views
    Left-click to view, right-click to download
    main
    dimensions
    exploded
    parts list
    Description
    -DISCONTINUED PRODUCT-
    Use as parts reference only
    Grip handles
    Paraffin cartridge
    Temperature and volume controls
    Temperature limiter stop
    "Economy" setting for water conservation
    1/2" hand shower hose connection
    Includes vacuum breaker
    1/2" male threaded wall unions,
    adjustable centers 5" to 7"
    Flow Rate
    4.8 gpm at 45 psi
    Code Compliance
    ASME/ANSI A112.18.1M
    ASSE Standard 1016
    Finishes and Suggested List Prices*
    34 067 OOO StarlightŪ Chrome
    $490.00
    Rough-In Valves
    N/A
    Jan 2009
    durham, nc
    Danz has a D500155 2 handle with vales that is pressure balanced. It is unusual in the the 2 valves, one for temperature and the other for flow volume, are set up horizontally with an 8" spread. For about $155, it also includes the valve body, But I don't think folks here thing much of Danze--is that right?
    Their website says limited availability so it may be limited to stock on-hand. http://www.grohecatalog.com/product/34066/
    Basically, its an externally mounted valve, tub spout with a built-in divertor. The second outlet on the bottom is for a hose for a hand-held shower. I've got a shower bar holding the hand-held. It's handy when cleaning things up since you can move it around easier. Except for the handles, the body of the thing is solid brass and probably weighs 10#.
