Steveleewonder
- Messages
- 25
- Reaction score
- 0
- Points
- 0
Hi,
I have coin-op laundromat store and sometimes I have some water related problem. On busy Sunday, water supply into my washer machines are not enough, so some machines do not working properly, it stops working and shows an error code it means certain amount of water has not been into washer within certain time period, so water level does not reach certain level(shortage of water).
That means water is not enough when many machines are running all together at the same time. During non-busy day, like weekday, all machines work fine.
My question is how to resolve this water shortage issue. My understanding is the more washers run, the lower water pressure, right?, so is there any water pressure booster pump to resolve my issue?
My store uses city water, so I am wondering how the water pressure is maintained from city main and inside store, during heavy consumption period? water pressure controlled and maintained by city? if "pressure boost pump" is installed, then it can really help to provide enough water to washer machines during peak time, regardless of main water pipe size?
Thank you,
Thank you,
