Results 1 to 4 of 4
Thread: Moen shower trim ID
    General Contractor dx's Avatar
    Jul 2005
    Michigan
    Default Moen shower trim ID
    I need help identifying this Moen shower trim. The valve is push/pull for volume, left/right for hot/cold. Does not tilt. The knob is 3-piece: The end cap screws on, then the wider piece, then the barrel. According to the customer, the 3 pieces were individually available in many shapes/finishes for mix & match.
    This trim apparently worked with both a pressure balance valve and with a non-pressure balance valve, as they have one of each in 2 different baths. There is no access to see the valves, but the valves are about 15 years old (early 90s).
    I'd like to know what valves/trims these are and if the trims are still available somewhere.
    Plumber jimbo's Avatar
    At first blush, I would have blurted out "P/P". But I think I can see the Moen stop tube, and you say it is Moen, so that probably makes it a Moentrol Concentrix. Check this: http://www.moen.com/shared/pdf/3100pt.pdf
    Default trim
    What do you want to do with the trim? If they have a pressure balanced valve using the same trim as the non pressure balanced, then it must be Moentrol version. The Moen site has many trim options for the Moentrol and they will work for the other valves also. That handle may not be available any longer because it was popular with all brands for a while and then died off.
    Jul 2005
    Michigan
    I want to replace it. Nothing wrong with it, but the crappy Kohler slide bar they had was broken and I replaced it with a chrome one as nobody makes a white shower anymore.
    So I'm just looking to replace the white trim with chrome or some chrome/white/gold combo depending on what's available.
    Thanks for the id guys, much obliged.
