Foundation Repair Question
PM5K
San Antonio, TX
Not sure if this is the right spot but I have a question regarding the quality of a foundation repair.
My in-laws had some foundation work done on their home, apparently there was a leak at either the washer or the water heater (They are right next to each other) that caused damage to the sub-floor and the sill beam?.
Anyhow, I have some questions about the quality of the work. Mainly I wanted to know if the size of wood that was used to replace the rotted wood is adequate (Obviously you guys don't know the exact code in my area but any opinions would be appreciated) and I want to know if it's ok that the sill beams at the corner don't butt together.
I don't know if sill beam is the correct term but in the pictures I'm referring to the pressure treated wood that was replaced.
TIA!
TedL
NY Capital District
There is no foundation in the pics. Three blocks do not a foundation make.
I hope there's not much in the way of winds either.
PM5K
San Antonio, TX
I guess my terminology is off, question still stands however.
There are a ton of those concrete piers underneath the house.
PM5K
San Antonio, TX
I honestly can't say. The house is in another city so I can't just go look at it.
If I had to guess I'd either say there is rebar in those piers that may be connected to the house, or it's just held in place by gravity.
How should it be held in place?
GregO
Virginia
wood
If those band boards (sill boards as you called them) are what they appear to be (4x6s on edge), they are smaller than ones I would have used given the span between pier footings, but I'd check a load table for your area.
Greg
PM5K
San Antonio, TX
Greg
Yeah I think they are 4X6 and the original are 4X8.
I wouldn't have said anything if the original had been 4X6 as well but since it wasn't I figured there must be a reason they used 4X8 in the first place.
I don't know anything about load tables, never even hard of it actually, lol...
SeattleSoxFan
jandmcarpentry.com
That is not a typical way of connecting floors to the foundation in many areas of the country. Is it a manufactured or modular house? My guess is the rim joist (what we would call the board that runs perpendicular to the joists, but "band joists" are used in some regions to describe the perimeter joists) is the 2x8(?) stacked on top, not the board precariously propped up on a few blocks. That is a beam that would be sized based on the area of the room it's supporting, the load (prob. 40psf), and the span. We do not know that information, nor any specifics of the codes in that area. We do call the board that rests on top of a foundation wall a "sill plate" but this is not a foundation wall, but piers... I think I can agree on "sill beam" :)
Terminology notwithstanding, you don't replace existing with smaller unless it was engineered or calculated out because it was usually calculated and specified as such originally. Given the connection between the piers and the beams I'm going to guess this was not exactly done according to code in the first place. Unless you are in a totally unregulated area of the country that's immune from all building codes (not sure if that even exists), that rim/beam/pier configuration would not be permissable at all. I'd definitely like to see some straps connecting at least the floor (rim joist & joists) to the beams, and something to connect the beam to the piers -- which would have to be drilled and epoxied (called "post-install" because it was done after the concrete was poured). I'd be pretty afraid to be near the house in a hurricane, twister, earthquake, dust storm, strong sneeze, or whatever typically hits your part of the world :)
I don't believe that pier foundations are allowed under load bearing walls... which one of those two sides certainly is (whichever side the roof starts on). They must be continuously supported unless an engineer has stamped their approval with an alternative. In either case there are minimum anchor bolt requirements in all buildings since the late 70's (given the sonatubes, I'd guess this is newer than that). Probably along the lines of 1 every 6' and within 12" of ends. So... that's for sill plates and continuous footings. Beams are usually connected via a metal connector appropriately sized for uplift and lateral wind loads. I've never seen the connector that is ok with ~5-1/2" space above the piers though! That's quite a lever arm that is set up.
But this is all a digression... The original question can be boiled down to:
  • Is sizing adequate?
Probably not. As I said, they would have had to reengineer the building, which I'm gonna guess they didn't do (why would they?). It's good they used PT, which the rest of the structure appears to be lacking. Technically only the wood that touches the cement or other moisture conditions that requires it, and that would be the "shim" material. I can't tell if that's PT or not. Cedar is not treated. BUT... that siding and belly band needs to be repaired or you will find that the kitchen or whatever that is sagging a bit more every year as the shims rot out underneath it.
Also that half-lap joint is interesting and probably not ok. It looks nice, but I see two problems. 1) It looks like there is a crack started in the existing beam because of the way the new was was propped up underneath it. 2) You have reduced the new beam to only a couple inches because that's all that's bearing! That is not a permissable notch. The new and old should just butt together over the support. Put a strap on it if you need them to be connected together.
  • Is it ok that the corners don't meet?
Probably. It's not the most professional result and there very well may be minimum nailing requirements (usually through a metal connector) to connect the beams, but the #1 thing is about the bearing on the pier and both pieces have plenty of bearing.
I'd also guess there is going to be a deck or something attached there? I'm not sure there is much I'd consider ready to attach a ledger to. There's plenty of wood, but I'm not sure it's attached to much to keep it from falling off/pulling off the building!
My $0.02 says to go with your intuition and try to get this fixed. If there is a building department in your city/county/region, you can usually request an inspector come out and take a look, but that could very well get the contractor in hot water, so maybe talk to them first to see if they can answer to your satisfaction or remedy it. They may have sent over someone inexperienced or some other excuse and would fix it. They also might have thought they could get away using some piece of wood they found on the ground... :)
Good luck,
- Jared
